pulling out cd-changer?
Old Apr 20, 2006 | 05:21 PM
ignazzio's Avatar
New Member
Default pulling out cd-changer?
<center><img src="http://img102.imageshack.us/img102/5756/cdchanger0017jm.jpg"></center><p>I've tried to pull out cd-changer on my 1998 Audi A6 today...unsuccessful attempt
I unscrewed the two bolts on each side of the cd changer, and there still is something what holds the device in that 'metal frame'...gentelmen, any suggestions?
Old Apr 20, 2006 | 05:31 PM
Pete RD's Avatar
Default Hmmm...there's a TECH article on installing the CD changer in the A6
...might check it out for the location of the screws.
Try the "resources" pull-down at the top of the page.
HTH
Old Apr 20, 2006 | 06:07 PM
mpw's Avatar
mpw
Default Take out the whole metal frame - 4 bolts , 1 screw IIRC from installing my Phatbox
From the Tech Article -
4. If you are removing the bracket as I suggest, do so now. There are 4 bolts and 1 screw. The bolts are 7mm you will need a socket set or spinner and a 3" extension will make it easier. The screw is a #2 phillips and you will need a screwdriver with a short or offset shaft. To remove the bracket, loosen the screw, then remove the bolts. You do not need to remove the screw. One bolt is behind a sticky cardboard panel on the left below the tail light. Peel the panel back and remove the bolt. Remove the bracket by lifting up on it. The right side will slide out from under the screw and the left side has a tab which will slide out of a groove it is in.
Old Apr 20, 2006 | 06:50 PM
Flint'sA6's Avatar
Member
Default 2nd that. I had to take mine out for PBox install as well. Don't remember
exactly how I did it, but it was straightforward and painless.
Old Apr 20, 2006 | 07:18 PM
Boston Driver's Avatar
AudiWorld Expert
Default For the lazy among us...
<ul><li><a href="https://www.audiworld.com/tech/elec37.shtml">here is the tech article!</a></li></ul>
VonPooper
Sep 5, 2008 06:22 PM
f3d
Oct 13, 2004 07:58 PM
DC Dawg (Married)
Feb 27, 2004 02:26 PM
computrtutr
9
Feb 4, 2003 08:49 AM
