What Octane?
Old Apr 22, 2006 | 11:18 AM
maxboston's Avatar
New Member
Default What Octane?
my A6 3.0 suggest 91, 87 at minimum. I have been running the 89 for 2 weeks. What do you guys run and suggest?
Old Apr 22, 2006 | 11:20 AM
DesmoTesta's Avatar
I didnt know it said 87 minumim..I was thinking I will HAVE to use 91 or better
Old Apr 22, 2006 | 11:22 AM
maxboston's Avatar
New Member
Default Re: I didnt know it said 87 minumim..I was thinking I will HAVE to use 91 or better
No the manual says that 87 is min. but 91 is optimum.
Old Apr 22, 2006 | 11:32 AM
Rocky-in-Connecticut's Avatar
Default from my experience with the VW/Audi non-turbo V6's
I would run the lowest octane fuel I could get away with (engine ping then move up a grade). These are cold running engines that frequently carbon up and create no start situations. And don't be afraid to give these engine weekly Italian Tuneups if you do not already put on lots of highway miles. if it says minimum 87, I would run 87 unless you get knocks and pings.
Old Apr 22, 2006 | 11:34 AM
DesmoTesta's Avatar
LOL..what is "weekly italian tuneup"..I am assuming redlining it a couple of times
Old Apr 22, 2006 | 11:46 AM
Randy Welch's Avatar
Member
Default yup. Just wind it up and let it rip.
Otherwise have fun with it!
Old Apr 22, 2006 | 12:39 PM
BernieBenz's Avatar
Default Bad advice IMO, Rocky! The ECU will adapt the spark timing to any fuel IF:
the knock sensors are functional. But you will never hear the knock before detonation has destroyed the engine if you have your foot into it at sea level.
Living at 4700' and driving to 10K, 87 Oct is totally adequate, but I'm very soft footed at sea level. Stock 2.7T, chipped 200Q-20V.
Old Apr 22, 2006 | 12:59 PM
4Driver4's Avatar
Tech Guru
Tech Guru
Default 93. Knock sensor will help ECU adapt. Better power and mileage on better fuel.
STFA. This has been discussed a million times.
 Pouria Savadkouei
 Michael S. Palmer
Old Apr 22, 2006 | 01:13 PM
BernieBenz's Avatar
Default Re: 93. Better power, BUT NO BETTER mileage on better fuel.
The heating value, calorie content of all (ethanol free) gasoline is the same.
Old Apr 22, 2006 | 01:29 PM
4Driver4's Avatar
Tech Guru
Tech Guru
...and timing is one factor that determines how efficiently that content will be put to use.
