2.8 cam chain tensioner gasket question
Old Apr 23, 2006 | 06:36 AM
nasdaqer's Avatar
New Member
Default 2.8 cam chain tensioner gasket question
I just pulled the valve covers, etc off the passenger side, I have the tool and all that, so ready to go... however, what is the long black hose that is just at the top of the engine bank, just under the fuel rail? it says >CM< and is attached to the top of the valve cover with a 10 mm bolt. Near the passenger compartment it runs over part of the cam adjuster. How to disconnect?
thanks
Old Apr 23, 2006 | 07:11 AM
nasdaqer's Avatar
New Member
Default if it helps --
the part thats over the cam tensioner is a hard line. it runs right over the top of the 1st of 3 bolts
help....
Old Apr 23, 2006 | 08:00 AM
4Driver4's Avatar
Tech Guru
Tech Guru
Power steering. Work around it. :-/
Old Apr 23, 2006 | 08:38 AM
nasdaqer's Avatar
New Member
Default Re: Power steering. Work around it. :-/
<center><img src="http://pictureposter.audiworld.com/97057/dsc03013.jpg"></center><p>wish I could, but the line runs right over the adjuster
Old Apr 23, 2006 | 09:16 AM
SoFla 2.7's Avatar
Default Break the line (as you did with the fuel rail) and then follow the hard line down...
...and unbolt the 10mm that holds it
Old Apr 23, 2006 | 09:18 AM
4Driver4's Avatar
Tech Guru
Tech Guru
Default BTDT. I know. Bentley tells you to remove the EGR stuff behind the head.
But they do not mention the PS line, IIRC.
I tweaked mine up a bit (looks like you already did) and worked around it.
Old Apr 23, 2006 | 11:10 AM
nasdaqer's Avatar
New Member
Default Re: Bentley tells you to remove the EGR stuff
I take it thats all the stuff behind the top of the intake mainfolds? So, unplug / undo all that stuff and then I will be able to disconnect the powersteering?
Am I in over my head? Yes. Did u AW guys tell me, a noob, to not do it myself? Yes.
help
Old Apr 23, 2006 | 11:55 AM
nasdaqer's Avatar
New Member
Default is the other end of the hard line
attached to the block? or the firewall area?
 Pouria Savadkouei
 Michael S. Palmer
Old Apr 23, 2006 | 12:46 PM
4Driver4's Avatar
Tech Guru
Tech Guru
Default Probably should have bought the Bentley first.
But anyway...
No the EGR just allows better access to the cam adjuster seal. I'd leave the PS intack if at all possible. It's a mess if you open it.
Old Apr 23, 2006 | 01:10 PM
nasdaqer's Avatar
New Member
Default is it possible to bend the
PS line at all? gonna order the Bentley tonight...
