Cyl 3 misfire???
Old Apr 23, 2006 | 08:50 PM
wgwebel's Avatar
Default Cyl 3 misfire???
Just had a cel come on and scanner says cyl 3 misfire. I just replaced the spark plugs 1k ago and when I swapped plug wires I get the same scan codes. Does this mean the coil pack is shot or am I looking for something else??
1998 A6 2.8 30V
Old Apr 24, 2006 | 02:54 AM
4Driver4's Avatar
Tech Guru
Tech Guru
Try swapping plugs first.
Old Apr 24, 2006 | 06:42 AM
NorCalS6's Avatar
might as well swap wires too.
Old Apr 24, 2006 | 07:47 AM
Rocky-in-Connecticut's Avatar
Default 6 cyl coil pack failure is rare
I would look at spark plug wires. Swap spark plug wires around and see if the misfire moves. Is it a steady misfire or sporadic? You might try misting the spark plug wires with a water spray bottle and note any arcing.
Old Apr 24, 2006 | 10:36 PM
Petethepug's Avatar
Default My 2.7 at the DLR for 25+ days for cyl 3 & 5 misfiring...
Keep an eye on the AR forum to see what the DLR finds. The car has already had the ecu replaced.
Michael
'02 Allroad 38K mi
Old Apr 25, 2006 | 04:30 PM
wgwebel's Avatar
Default Re: Try swapping plugs first.
Swapped the plugs and it cleared and ran well for one day and now the cel has the same cyl 3 misfire code, am also getting a P1227 fuel air metering but i am assuming thats from the misfire. I have it scheduled on Thursday for a complete engine diagnostic at a credible local shop so I guess I'll see?
Thanks very much for all your help!!
winder
9
Jan 26, 2016 07:49 AM
1999Audi
Feb 27, 2014 11:12 AM
nickel4490
A4 (B7 Platform) Discussion
Mar 23, 2006 07:12 PM
TTspeed4me
Jan 28, 2005 04:58 PM
DrewP
Aug 13, 2002 01:07 PM
