Anyone else have their S6 jack blow up whilst changing a flat tire?
Old Apr 24, 2006 | 04:09 PM
jayfitz's Avatar
New Member
Default Anyone else have their S6 jack blow up whilst changing a flat tire?
Mine did on a dead flat parking lot- luckily the doughnut spare was in place to catch the car but upon inspection of the jack, I'd have to say it's the cheesiest, cheap POS imaginable, especially in light of it being provided as equipment on a $60k car---
Insult to injury is that the warranty expired only days before.
Anyone know of a source of a better quality jack that will stow reasonably well? A OEM replacement is $140.
Be safe kids!
Old Apr 24, 2006 | 04:45 PM
Boston Driver's Avatar
AudiWorld Expert
Default You're lucky...there was a guy here that got his hand trapped when his collapsed...
I would suggest you invest in a small bottle jack for the car.
Old Apr 24, 2006 | 05:21 PM
néné's Avatar
Member
Default I've heard of the RS6 jacks coming apart while changing tires
It is possible that they use the same jack on all the C5 cars.
Old Apr 24, 2006 | 05:42 PM
Press's Avatar
Fear the Miata!
why would anyone use the oem jack for anything other than a door stop.....?
Old Apr 24, 2006 | 05:50 PM
saabSean's Avatar
Default Is it the standard jack? Because I use mine all the time
Every season, when I swap wheels in my driveway, I use the standard jack.
Are we now saying that these "half a jack" units fail?
Old Apr 24, 2006 | 07:42 PM
LCP's Avatar
LCP
AudiWorld Expert
Default 'Tis is a question asked a hundred times on every forum on AudiWorld...
...although usually the thing just loses its balance and falls over. The one on that's with my allroad seems of beefier construction than the one that came with my S4, or maybe the black metal just looks beefier than the silver metal...
Old Apr 25, 2006 | 04:32 AM
Edd W's Avatar
Default I have used the OEM jacks on various VAG cars and never had a problem but I can see...
that it is critical that the car cannot move at all.
Any lateral movement could cause the it to twist and loose its strength then just fold up.
Old Apr 25, 2006 | 06:30 AM
TXurS6's Avatar
Default Here's what I bought
Comes in a case (16x7.5x6) and the saddle has a slot that matches our jack points.<ul><li><a href="http://www.jcwhitney.com/autoparts/Product/tf-Browse/s-10101/Pr-p_Product.CATENTRY_ID:2008312/showCustom-0/p-2008312/N-111+600002481+10201/c-10101">Portable Hydraulic Scissor Jack</a></li></ul>
 Pouria Savadkouei
 Michael S. Palmer
Old Apr 25, 2006 | 09:27 AM
v8a6's Avatar
Default Mine failed on me too.
I honestly dont even think it is safe to use in any situation, after the failure. Any kind of movement to the car, from pulling off a wheel for example, can bend the little base of the jack, and tip it over.
I replaced mine with a full aluminum jack that I keep in the garage. Emergency road side tire changes and Im calling CAA. I have a full membership that I barely use anyway.
ryoung
19
Aug 6, 2014 02:18 PM
Dramsey
A6 (C7 Platform) Discussion
25
Apr 20, 2013 10:14 AM
jayfitz
13
Jul 14, 2008 05:18 AM
esanmiguel
14
Feb 25, 2008 04:14 PM
ripley
Feb 2, 2003 05:07 PM
