Removing Parcel Shelf
Old Apr 25, 2006 | 07:35 AM
ppinto1's Avatar
Default Removing Parcel Shelf
I have a 2002 A6Q Sedan. The Bently manual procedure for removing the parcel shelf involves removing seatbelts and the sides of the seats. Has anyone done this in a less complicated way? Thanks in advance.
Old Apr 25, 2006 | 08:56 AM
Boston Driver's Avatar
AudiWorld Expert
Default Unfortunately, removal of the shelf requires lots of other stuff removed first...
You ahve to remove the seatbacks and the side bolsters beacuse of teh seatbelts that run through the holes in the shelf. To remove the shelf itslef, you also have to remove the C- and D-pillars, which are not that easy. Follow the Bentley...there is no shortcut.
Old Apr 25, 2006 | 09:50 AM
ppinto1's Avatar
Default Re: Unfortunately, removal of the shelf requires lots of other stuff removed first...
Thanks for the tip. I've already got the D-Pillar molding off on the driver's side. I guess I'll do the passenger side as well, since there are connections for the antenna amp I have to check there. What I'm really after is checking the connections of the Diversity Antenna Selector. Can this be accessed without removing the parcel shelf? Thanks.
Old Apr 25, 2006 | 11:55 AM
AudiWorld Expert
Default You also have to remove the C-pillar (little triangle around window)...
that piece holds in a large "hook" on the side of the rear shelf. You need to remove 3 or 4 torx bolts along the rearward edge (IIRC) and then pull towards the center of the car to release the metal clips.
Bimmer Needs Reverse
Jul 29, 2008 04:31 PM
2000s4biturbo::Uli
Oct 9, 2006 02:24 PM
BlackAudiA4
Jan 4, 2006 07:20 PM
addifan
May 4, 2002 03:23 PM
Milhouse
Jun 1, 2000 11:33 PM
