ECU problem, need help
Old Apr 25, 2006 | 02:17 PM
dool's Avatar
Default ECU problem, need help
failed inspection because ECU does not communicate with the inspection computer. Took it to dealer and was told the ABS ECU and module are bad and thats why the main ECU doesnt communicate.
Does it make sense? they want 2500 to change the ABS ECU + module.
Thanks
Old Apr 25, 2006 | 02:27 PM
mpw's Avatar
mpw
Default Don't give them $2500!! Do a search on ModuleMaster first....
any other symptoms? ABS light? Beeps? Flashing BRAKE light?<ul><li><a href="http://www.modulemaster.com">Click</a></li></ul>
Old Apr 25, 2006 | 02:34 PM
dool's Avatar
Default Re: Don't give them $2500!! Do a search on ModuleMaster first....
Yes, all of the above with the lights and beeps. But I find it hard to logically think that the ABS system would prevent communications of the main ECU to the states computer
Old Apr 25, 2006 | 02:40 PM
mpw's Avatar
mpw
Default It can and does.
It's pretty easy to pull the module yourself and you can get it rebuilt by ModuleMaster for &gt;$300. I think the rebuilt unit is probably better than a new one.
Search the forum for ABS, ModuleMaster, etc. There is a bunch of info on this.
Good luck!
Old Apr 25, 2006 | 03:14 PM
donp's Avatar
Yep. Get it fixed. Mine should be back tomorrow if fedex doesn' t lose it.
Old Apr 26, 2006 | 03:47 PM
dool's Avatar
Default Re: It can and does.
Thanks for your help, will pull it out this weekend
SLOGARO
VAG-COM Discussion
Dec 7, 2007 08:31 AM
freakness
Nov 27, 2007 11:03 AM
addìct
Oct 17, 2005 03:13 AM
SmokinS4™
VAG-COM Discussion
Nov 21, 2003 09:22 AM
EKoS
Oct 9, 2003 10:50 AM
