02 A6 owners..Do you guys change oil once a yr (10K miles) or get usual 3K-5K oil changes
Old Apr 26, 2006 | 06:33 AM
DesmoTesta's Avatar
Default 02 A6 owners..Do you guys change oil once a yr (10K miles) or get usual 3K-5K oil changes
My car has 37K..last oil change was in Sep 05, since than the car was driven 1100 miles, yes 1100 only...
I am wondering if I shoudl start my own 5K Mobil 1 oil cycle or go with Audi recommendation 10K oil changes..
what do you guys say?
Old Apr 26, 2006 | 06:59 AM
bm196, '02 4.2's Avatar
Every 5,000 with Castrol Syntec 0W-30 (European Formula).
Old Apr 26, 2006 | 07:00 AM
dave240Z's Avatar
Default I usually change at 5K intervals using synthetic
It's most likely overkill, but it's not terribly expensive since I do it myself.
BMW has similar intervals (actually via a countdown on the dash) and I have seen a few pictures of sludge buildup in those engines.
For the cost and time involved in doing the change, I figure it is cheap insurance. Plus, I don't think Audi could frown on you for changing the oil too often, whereas not changing it often enough might cause problems.
Old Apr 26, 2006 | 07:15 AM
LuvnhatemyA6's Avatar
Member
Default If you're not happy doing 10K, split the difference and go for 7500.
5K is certainly more frequent than necessary and a waste of money, not to mention waste of a precious resource.
You don't have turbos to worry about.
Old Apr 26, 2006 | 07:20 AM
TRed 2.7T's Avatar
Default I do every 5K with Mobil 1, 0-40. But you don't have turbos so 10k should work fine and you
will be within specs for the car.
Old Apr 26, 2006 | 07:21 AM
Audi2Ody's Avatar
Default Everyone has a different opinion but I think that without turbos, synthetic every 10K is fine.
When I had a turbo with a 1 bar chip, I changed synthetic every 7.5K and it was running great when I sold it at 106K.
Old Apr 26, 2006 | 07:35 AM
ado_dado83's Avatar
Member
Default I got 3.0 FWD
and I change oil every 8ooo miles.
Castrol SYNTEC ONLY 5w50 if Im not mistaken
You should change your oil since its been in the car for almost a year now.
let it breathe some FRESH syntec.
Old Apr 26, 2006 | 07:41 AM
Member
Use the proper OEM 15K oil filter
 Pouria Savadkouei
 Michael S. Palmer
Old Apr 26, 2006 | 08:27 AM
myfirstimport's Avatar
Default My 2000 gives the oil change reminder at 7,500 so thats when I do synthetic and filter
works out to be every 6 months.
Old Apr 26, 2006 | 09:11 AM
Ritz's Avatar
Default 2nd...I do oil/filter every 5k on my 2.7T...
I had been using M1 5W-40, but I've switched to Delvac 1300 15W-40 recently. It seems to be doing a good job of slowly dissolving the brownish "nicotine stains"/light varnish in the engine (from what I can tell with the borescope).
Cheers,
