chipping a 2002 A6 2.7t w/ 40K
Old Apr 26, 2006 | 11:25 AM
BiturboA6's Avatar
Default chipping a 2002 A6 2.7t w/ 40K
I haven't done any performance upgrades with my 02 A6. Would it be tough on the car with 40K miles?
Thanks,
Drew
Old Apr 26, 2006 | 11:26 AM
Kris Hansen's Avatar
Head Cat Herder
25 Year Member
Just do it... =)
Old Apr 26, 2006 | 11:34 AM
absolutcq20v's Avatar
Treat an Audi with regular maint., repairs as needed, and no abuse and it will run forever.
Old Apr 26, 2006 | 11:39 AM
Ritz's Avatar
It will completely change (for the better) the car. Get the 710N bypass valves too.
Old Apr 26, 2006 | 12:32 PM
TRed 2.7T's Avatar
Default I chipped my at 45K and have 75K now with no issues! The dark side waits for you! :)
If you do chip, upgrade your TBB and DVs as well.
Old Apr 26, 2006 | 12:51 PM
DesmoTesta's Avatar
Does that hold for the N/A engines as well..reg maint/repairs and will run for ever..?
Old Apr 26, 2006 | 01:27 PM
Ernesto (ERT)'s Avatar
Chipped mine at 100k, the APR bi-pipe is highly recommended "peace of mind"
Old Apr 26, 2006 | 03:47 PM
Capt William's Avatar
Default I can't see how the milage would have any effect.
If there is something wrong with your clutch or you have a weak TBB (throttle body boot) then you may cause those parts to fail (or at leat notice the failure more) but other than that I don't see an issue. By the way I would recommend getting a Samco TBB (about $75) whether you are going to chip or not, but even more so if you are chipping. The TBB is a definite weak spot, I have seen 5 failures between my 2 2.7ts, in about 40,000 miles total.
 Pouria Savadkouei
 Michael S. Palmer
Old Apr 26, 2006 | 04:27 PM
HooosUrDaddi's Avatar
New Member
Default A chip will give you a dramatic change...
I agree with recommendations to get bi-pipe and diverter valves.
good luck
al
Old Apr 26, 2006 | 05:05 PM
A6turbo530's Avatar
how many mile have you put on with the chip? origional turbos or no?
