Archives prove incomplete. Turn Signal Relay?
It was showing up green when indicating on the dash once, then stays black but continues to make the clicking noise.
Now, it does not lihjt up at all, but the hazzards still function correctly and the outside lights seem to be functional as well.
Just the indication from wthin the car, on the dash seem to have stopped working, or are intermittant.
Just started today, turn car on and of, and on again, no difference.
Fuse?
Relay switch or can VAG spot the issue? If so, I should probabaly run it....
Had emissions test yesterday and it passed but I wonder if their OBD effected the turn indicators some weird way.
Hopefully I can use VAG to evauluate and reset any fields.
We'll see, unless someone here has some more solid directions for testing before I bug a Chicagoan for use of their VAG.
Thanks.
