if a "liquid" flows down the upper center vent (above the radio). can the liquid reach a circuit boa
Old Apr 28, 2006 | 05:34 AM
audi2.7audi's Avatar
Default if a "liquid" flows down the upper center vent (above the radio). can the liquid reach a circuit boa
or something that would affect the tachometer (intermittent) and warning lights for check engine oil (also intermittent) ... I find it hard to believe it could.....prior to spilling the "liquid" (coffee)...I did have a brake pad warning light flashing, however my front pads are fine.
I did try cleaning the cluster connectors per Boston, but no luck.
any suggestions.....could I have a bad ECU? thanks everyone.
Old Apr 28, 2006 | 06:29 AM
absolutcq20v's Avatar
Default If the pad wear circuit is closed, oil is good, and tach has a good signal (verify w/ Vag-Com)...
...then it sounds like your cluster may have a problem(?)
Are any codes stored in the cluster, engine, etc. controllers? Worst case, you may have a problem with the harness...although I'd say the cluster is the most likely culprit. Maybe find a used one to swap in(?) Good luck with it!
Old Apr 28, 2006 | 08:14 AM
LuvnhatemyA6's Avatar
Member
Default I've done this, only problem it caused was the tea pouring out of the foot vents!
Should be fine.
f20cdriver
Jun 5, 2009 07:52 PM
yecats
Audi 100 / A6 (C4 Platform)
Feb 8, 2007 08:01 AM
audi2.7audi
Apr 28, 2006 05:13 AM
[Arawan]
Apr 20, 2004 04:22 PM
Brdman*
Dec 30, 2003 12:11 AM
