Torque specs for cams
Old Apr 28, 2006 | 02:33 PM
nasdaqer's Avatar
New Member
Default Torque specs for cams
just took out and replaced the cams - long story. Can u tell me what torque to wrench them down to? same as the cam chain tensioner, 7lb/ft, I believe?
Old Apr 28, 2006 | 03:02 PM
4Driver4's Avatar
Tech Guru
Tech Guru
Default I think so, but verify with Bentley or someone here that has Bentley. Remember...
The torque spec is meaningless if the wrench isn't set right or if it is too large for the job. To torque 7 ft-lbs, I wouldn't want a wrench capable of any settings over 50 ft-lbs.
Achtung! Most torque specs are given in both ft-lbs and newton-meters. Make sure you are checking your units both when you read the spec and set the wrench.
Old Apr 28, 2006 | 03:31 PM
mpw's Avatar
mpw
Default From the Bentley - Tightening torque: 10 Nm (7 ft lb).
For both the 2.7 and 2.8 engines.
Good luck! Sounds like this has been a real test, but you're on the home stretch now.
Old Apr 29, 2006 | 01:35 PM
nasdaqer's Avatar
New Member
Default thanks mpw and also a big thank you to 4driver4
and all the others. Doing the cam chain tensioner and valve cover gaskets has been quite the experience. What I have learned:
1. Move the power steering line from behind the engnine block - you don't need to disconnect it, just unscrew the 13mm bolt that holds the line to the back of the block. Hard to find, but its back there.
2. No need to remove the cams... unless u broke a bolt like I did....
3. Buy the Bentley!
4. Make sure your torque wrench is calibrated.
5. Take your time. We have 2 cars, so it wasn't such a big deal, but it did turn out to be a week long project since the local audi dealers here in Mpls didn't have extra cylinder head bolts (for the cam chain tensioner).
Again - thanks to everyone on the board!
Next: front pads and rotors, tie rods, and timing belt / water pump. Oh - and the accessory belt.
I'm sure I'll be back with more questions. Again, thanks for all the insight.
Nasdaqer
Old Apr 29, 2006 | 02:06 PM
nasdaqer's Avatar
New Member
Default I didn't put any sealant on the three ringed gasket --
I didn't see anywhere where it said to - is that going to be ok?
dakinejb
Feb 15, 2017 11:57 PM
jayd2s8
30v V6 Discussion
Aug 17, 2014 04:26 PM
hindswillrox
Jun 1, 2010 08:46 AM
CO2000A418T
Jan 18, 2005 04:37 PM
bogelo
12v V6 Discussion
Apr 22, 2003 01:55 AM
