Bleeding brakes on 01 A4...
Old Aug 2, 2002 | 05:52 PM
James R.'s Avatar
Default Bleeding brakes on 01 A4...
Ok I'm going to do a brake fluid flush on my car...first time for me on the A4.
It says if you have manual transmission you must bleed the clutch...
They claim you do the following. Remove resivior cap...open right rear caliper bleed screw, with the engine running pump the brakes until you empty the resivior to the point of the clutch feed line. Fill the fluid back up, then bleed the clutch? Where is the screw for that...?
I assume you do the clutch first...then you do Right rear, Left Rear, Right front & Left front...furthest to closest to the master cylinder. It say in the bentley to bleed out 15oz per caliper...that seems like an awful lot to me...that's 60 Oz for the calipers...and another 6~10 for the clutch...I suppose since it's a flush maybe ok...I guess it's cause I've only bled the brakes so I'm used to a few oz here and there...not nearly 100 Oz of fluid.
Regards,
James R.
Old Aug 2, 2002 | 06:26 PM
WYSIWYG's Avatar
Default just use a clear bottle/hose so you can see whats coming out, then stop when the new fluid is coming
out. bleed for the clutch is under the coolant reservoir accessed from under the car
Old Aug 2, 2002 | 06:28 PM
WYSIWYG's Avatar
i just used about 1.5 liters for the back, 1 liter for the front/clutch.
Old Aug 2, 2002 | 08:43 PM
got_root?'s Avatar
Member
isn't that only if you have ESP?
Old Aug 2, 2002 | 09:46 PM
Steveo369's Avatar
Default You might want to look into this...
I don't know how "true" it is, but there's been recent discussion on the VAG-Com Mailing list about triggering the ABS pump when bleeding the brakes. (see the thread "how to cycle abs pump")
Not using the ABS pump to powerbleed, but just to make sure you get all the fluid out.
Procedures for pumping the ABS pump are in the Bentley, but I haven't looked to see if there's any recommendations on doing this or not doing this during the fluid change.
(From your other posts, I know how A.R. you are, I just figured I'd throw in another thing to worry about)<ul><li><a href="http://groups.yahoo.com/group/VAG-COM/">http://groups.yahoo.com/group/VAG-COM/</a</li></ul>
Old Aug 2, 2002 | 10:51 PM
James R.'s Avatar
Default No Chit...you have to get at it from under the car?
I assume it's pretty obvious...like you can see where the line runs and there's a screw to **** down there?
Old Aug 3, 2002 | 05:27 AM
WYSIWYG's Avatar
yup same bleed valve
Old Aug 3, 2002 | 08:20 AM
Silvr1.8T's Avatar
Junior Member
Do it like any other car just do not let the master cylinder suck air.
 Michael S. Palmer
Old Aug 3, 2002 | 08:49 AM
Perpetual Novice's Avatar
Default I suggest buying or building a pressure bleeder.
It holds a reservoir of fluid and applies positiver pressure to the car's reservoir. No pumping of the brakes required (Which is a good thing, you can ruin seals pumping the pedal with a bleed screw open)
It's also faster, takes about 10-15 minutes once the thing is built.
Cost $25 bucks to make it yourself, see the tech section.
Old Aug 3, 2002 | 11:44 AM
James R.'s Avatar
Heheh thanks...actually I have the Motive unit, just haven't used it yet :-)
