cheap giac chip on ebay- not mine
Old Aug 3, 2002 | 09:43 AM
coocoomike's Avatar
Default cheap giac chip on ebay- not mine
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&amp;item=1847319551<ul><li> <a href="http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&amp;item=1847319551">http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&amp;item=1847319551</a></li></ul>
Old Aug 3, 2002 | 10:26 AM
stsai's Avatar
New Member
Default Re: cheap giac chip on ebay- not mine
Wow, I've been thinking about chipping my car. That looks like a good price. What do I need to install it? Can I do it myself or is it something for the tuner shops to do? How much would it cost for a shop to put that in?
Old Aug 3, 2002 | 10:32 AM
A4_THOR's Avatar
Member
make sure that if you buy that particualr chip that your car is a non drive by wire because that chip is from a 2000 A4 which is non-drive by wire
I spoke with awe-tuning and they told me a non-dbw chip cannot be recoded to a dbw chip
I wouldnt try to do it yoursef unless your real good with a souldering gun.
the best is awe-tuning they will socket the chip and let you keep your stock chip
Old Aug 3, 2002 | 10:39 AM
stsai's Avatar
New Member
How do I know if my car is a non drive by wire? I have a 2000 1.8T Quattro 5sp. I know how to solder, but I guess I don't want to risk it. How much do tuner shops usually charge to put a chip in? My stock chip isn't too much of a concern for me seeing how warranty is gone in less than 100 miles.
Old Aug 3, 2002 | 10:42 AM
coocoomike's Avatar
2000 is DBW?
Old Aug 3, 2002 | 10:52 AM
A4_THOR's Avatar
Member
Start your engine , Pop open your hood , do you see a wire/cable to the right of your engine , can you press it to rev your engine? if so then you have a drive by wire. If it is not there then you are a non-drive by wire (it is electronically controlled) I am 99.9% certain that 2000 is the first year when non-drve by wire began....but doublecheck i could be wrong
I think most shops will charge apx. $50 for the install.
Old Aug 3, 2002 | 10:54 AM
A4_THOR's Avatar
Member
Default Re: 2000 is DBW?
no, 200 should be non-dbw
Old Aug 3, 2002 | 11:04 AM
coocoomike's Avatar
im pretty sure it is DBW, 1999.5 was the last NDBW model
 Pouria Savadkouei
 Michael S. Palmer
Old Aug 3, 2002 | 11:05 AM
coocoomike's Avatar
ah, i see. Computer controlled is actually called DBW, older ones are controlled by throttle cable
Old Aug 3, 2002 | 12:17 PM
A4_THOR's Avatar
Member
Default Re: ah, i see. Computer controlled is actually called DBW, older ones are controlled by throttle c
your absolutely correct i keep thinking wire = physical wire like a throttle cable ....but in audi's case 'wire' is an electronic wire.....they should have called it something else.
