If you code tranny to sport-mode, and then add the basic chip upgrade to 318HP
Old Jul 20, 2007 | 10:08 AM
LeftLaneA6's Avatar
Default If you code tranny to sport-mode, and then add the basic chip upgrade to 318HP
is it nessecary or advisable to get a tip-chip upgrade or is the sport-mode re-code sufficient?
Thanks in advance for your input..
Old Jul 20, 2007 | 10:44 AM
JimmyC83's Avatar
Default people say the gear ratios arent "comfortable" without the tip-chip
i never found out because i flashed both ecu's immediately,sry
btw the tip recode makes your pedal response more aggressive and sporty in both auto and tiptronic mode...00032 is the code.
Old Jul 20, 2007 | 11:15 AM
LeftLaneA6's Avatar
Default Racin' green - sweet! Where's the Sig photo from...? Also,
what does the mean you flashed the ecu 2x?
Did you erase it? NOOB to ecu issues. FYI
Old Jul 20, 2007 | 01:01 PM
JimmyC83's Avatar
Default erm, when it comes to our non 6MT's
Sig photo is boston on the charles river on the MIT university side...but soon to change pic =)
glad we have another racing green machine with us!
IIRC, we have technically two ECU's built into our systems
http://www.goapr.com/Audi/support/ecu_a6_allroad.pdf
i had my OEM audi ECU flashed (not replaced) to a GIAC 'firmware', and the other tiptronic ECU flashed also to the GIAC TIP 'firmware'. you may have tuners do this, or you can simply purchase and hot swap with a ECU that has already been flashed from its stock programming. Though i'm not sure if it involves any soldering in the process (most likely yes)
expect to pay $500(x2) for each flash + 100$ installation charge
= 1,100$ or so...
(best buck i've spent in years)
(unless you get the discount and done in person at waterfest this weekend)
Old Jul 20, 2007 | 03:19 PM
MCH 2.7t's Avatar
Member
Default "Sport-mode" does nothing to increase the speed of shifts...
The real benefit of the 00032 code is that it allows you to hold 1st gear to redline. Normally, the tranny will short shift the 1-2 shift.
The GIAC tip chip noticeably increases the speed of up and down shifts when in Tip mode. There is still a delay from the time you move the shifter (or push the button) and the time the tranny shifts, but it is faster with the Tip chip. IMO, it is well worth the investment.
Note that O.CT also has a Tip chip. However, their Tip chip is very different from the GIAC Tip chip. As I understand from talking with Strat and Marcus at O.CT, the stock TCU limits how much torque the ECU will allow the motor to develop. The O.CT Tip chip (and the GIAC) eliminate this safeguard. The O.CT Tip chip does not increase the speed of shifts. Marcus was working on this, but don't know if he ever finished development.
I've got no idea what the Dahlback Tip chip does.
HTH
Mike
Old Jul 20, 2007 | 03:50 PM
2.7T_RT(toofast)'s Avatar
Default Ride was unhappy with GIAC ECU code only, sporadic shifts - methink the extra torque throws it off
Once I put the Tip-Chip in - only delayed 9 months because of a $hitty dealer I ended up firing - it shifted noticeably better.
Sigh, still no fix for the dreaded BTDL...
Old Jul 20, 2007 | 04:57 PM
JAGMAJ's Avatar
Is Tip Chip much slower than MT or much faster than sport mode?
Old Jul 20, 2007 | 06:53 PM
Default With a good launch, Tip chip can nearly make up the difference on an MT- Def faster than sport mode.
Sport only raises the shift point RPM and holds first gear to redline upshift or manual upshift, it does nothing to speed up shifts, just like MCH 2.7t said.
 Pouria Savadkouei
 Michael S. Palmer
Old Jul 21, 2007 | 08:27 AM
Grapeking's Avatar
25 Year Member
one of these days I'd like to ride with you to feel the difference w/ the flash.
trailertravis13
VAG-COM Discussion
Jan 27, 2008 07:14 PM
Alpha7
VAG-COM Discussion
Feb 24, 2005 02:43 PM
wawazat
Jan 22, 2003 12:49 PM
S4@last!::Now B7 RS4
May 18, 2001 08:19 PM
