Trim swap help
Next are holes for the 6spd console and the Tip the same size? They appear to be but when I swapped the narrow alum. bezel from my 6spd to the new Tip console it will not fit in the hole perfect as it is slightly too big. I have tweaked it but still no joy!
Yes, the glovebox trim is very stubborn. THere are four long pegs that hold that sucker in. If you pull too hard, you might crack the clear resin coating over the wood.
Best to use a plstic putty knife on the bottom edge and try to coax it out.
Good luck!
