Heat blowing out of left side vent when A/C is on
Old Jul 21, 2007 | 08:04 AM
Aces's Avatar
New Member
Default Heat blowing out of left side vent when A/C is on
May have posted this to wrong forum, so I'm posting in here on A6/C6:
Has anyone found a resolution to this issue? I have a 2004 A6 4.2. Several times recently, after driving for 30 minutes or so with the A/C on, heat will start pounding from the driver's side vent. Can't get it to stop.
Outside air temp was around 85 degrees, A/C set to 72ish. Once, the heat was coming out of the left center vent too. Other times it was just the driver's vent by the door.
Anyone find out what causes this?
Bill
Old Jul 21, 2007 | 08:32 AM
4Driver4's Avatar
Tech Guru
Tech Guru
Default Have the system checked for a correct charge.
Low refrigerent level will do that sometimes.
Old Jul 21, 2007 | 08:16 PM
LIRS6's Avatar
Default Same issue recently, dealer drained/filled with dyed refrigerant and removed/reinstalled
evaporator restrictor. Schrator valve was leaking, tightened evacuated & charged. So says the paperwork.
rassi
A6 (C7 Platform) Discussion
17
Oct 4, 2018 11:51 AM
4Driver4
Aug 2, 2012 07:06 PM
RingsOfFire
Oct 31, 2007 10:22 AM
A8CT
Jul 21, 2007 08:00 AM
mingbleu
Apr 11, 2006 05:12 PM
