Need some help -- been searching but now more confused
Old Jul 21, 2007 | 06:08 PM
Willis99's Avatar
New Member
Default Need some help -- been searching but now more confused
Have an '02 A6 2.7t - does NOT have HP-2 front brakes. I'm REALLY trying to figure out what the size the front rotors are (looking for stock replacement)?
Is is 321x30 or 288mm? Also, does the 22.7 and 16.7 offset just apply to the 321x30 size?
Any insight (on size and online suppliers) would be MUCH appreciated.
Thanks in advance!
Old Jul 21, 2007 | 06:55 PM
Flint'sA6's Avatar
Member
Default Not to confuse the situation, but there's 312mm too. what size are your wheels?
Bentley shows 288mm for 15" wheels, 312mm for 16" wheels, then a listing for 321mm with no specification of wheel size (could apply to 16" or 17" I suppose). If you have 17" wheels, it'd be a safe bet that your rotors are 321mm.
With this somewhat iffy info I'd be inclined to call a supplier w/ the VIN to find out for sure.
Old Jul 21, 2007 | 07:55 PM
MikekiM@PureMS's Avatar
Former Vendor
Default Front is 321x30mm for ATE caliper
With the ATE caliper, you want these.
8E0 615 301 AD
Available from us, just plug in that PN in the search. These are indeed a small offset hat rotor than the prior models.
288mm rotor never came on the 2.7T.
Old Jul 22, 2007 | 07:28 AM
Willis99's Avatar
New Member
Thanks! Just checked measurements myself (DUH), you're right and order has been placed.
Old Jul 23, 2007 | 07:05 AM
Former Vendor
Default Thank you..
Looks like your order was for a different rotor, the 8D0615301M which is most typically used with the HP-2 caliper, not the PN I listed above.
Old Jul 23, 2007 | 07:10 PM
Willis99's Avatar
New Member
Default Crap - Didn't mean to
Thought I ordered the Zimmerman version of the PN you noted. SKU: ZR.8E0615301AD
Is it to late to change the order? I think these are a bit cheaper than what I actually ordered (you can keep the change .. <gg>
Old Jul 23, 2007 | 07:34 PM
Former Vendor
Default Whew
I held the order until I was sure. I'll go ahead and make the change tomorrow.
Old Jul 24, 2007 | 03:47 AM
Willis99's Avatar
New Member
Thank You! -- Sorry about that
 Pouria Savadkouei
 Michael S. Palmer
arhy
9
Dec 15, 2011 11:57 PM
anatharaa64.2
Jan 9, 2009 08:24 AM
maxboston
May 9, 2007 08:34 AM
A6_machine
Jul 9, 2003 07:06 AM
