Audi all wheel drive vs. BMW's
Old Jul 22, 2007 | 08:57 PM
2016A63.0T's Avatar
Default Audi all wheel drive vs. BMW's
Anybody know the exact difference between Audi's quattro system and the system in the BMW 535ix?
Am on my second A6 2.7T (5th Audi altogether) and drove the Bimmer yesterday and was very impressed as one would expect with 300HP and 300 lbs./ft torque. Great suspension. Interior not as nice as Audi's-no surprise there. Wondered how the Bimmer's all wheel drive might perform in the snow and ice compared to Audi's.
Thanks!
Old Jul 22, 2007 | 09:12 PM
LEH82's Avatar
Junior Member
Default I drove one too and I must say it was a nice experience and with Audi's lack of standing behind thei
r warranty...I'm looking at the 335xi and hoping the 535xi will get a make over.
Old Jul 22, 2007 | 09:25 PM
ndjano's Avatar
Default i've driven both through some nasty stuff-- both are nice systems
IIRC, the early stage of x-drive was just an AWD system and had no power-shifting capabilities. The modern x-drive system does have the ability to shift power to individual wheels like quattro. However, I'm not sure if x-drive has locking differential. At the end of the day, they'll both take you where you need to go. If they can't get you there you probably shouldn't be going anyways ;-)
As for the handling advantages on dry roads, well the BMW wins there no matter what the drive system.
I like driving the X5 when it gets real nasty just because of the hill decent control... but now it is history :-(
Old Jul 23, 2007 | 06:11 AM
audikillsbmw's Avatar
Member
In the very least, it has to be better than MB's "4Matic" system :P
Old Jul 23, 2007 | 06:31 AM
koz4.2's Avatar
Member
Default Really? They're pretty much the same, 40/60 split, with the ability to send power where needed...
A formula Audi is switching to as well.
Koz.
Old Jul 23, 2007 | 07:08 AM
reapersA6's Avatar
New Member
Default Audi's all wheel Drive uses friction to sense where torque is needed, BMW uses wheel sensors to ...
detect variances in wheel speed. They then send the power to the wheels that are moving the slowest. Audi's system works much fast and what could be considered pro-actively, while as BMW's, MB's, etc. all use the latter method which is retro-active. If pushing the car hard, the Audi will come out ahead every time, because the BMW waits to lose traction before power gets shifted, Audi always sends the power to the wheel with the most traction (friction) before slippage is caused. The Audi will only lose traction when there is nothing available and ALL the wheel Forward or Aft are tractionless.
NOW, Audi is also working on producing a few new AWD systems that will blow people away. This is going to use new clutch systems in the differentials and allow a much broader power distribution, including cross car distribution where power can be sent instantly from left rear to right front and vice versa allowing the first AWD system with absolutely infinitely variable power distribution amonst the 4 wheels.
Old Jul 23, 2007 | 07:57 AM
Member
Default I drove one in the rain once (don't ask me why,) and it wasn't nearly as nice
as the Quattro system. Kind of hard to explain... Car felt "unpredictable" to me, and a little less refined than Quattro.
Old Jul 23, 2007 | 11:03 AM
GTA_Driver's Avatar
Tech Guru
Speaking of Audi's "super"-AWD system... read a good article that they are looking at Honda's SH-AWD
 Pouria Savadkouei
 Michael S. Palmer
Old Jul 23, 2007 | 12:17 PM
April's Avatar
AudiWorld Uber User
Default Why would Audi bother? They appear to be going with Torque Vectoring
BMW uses one system that is shared among BMW cars and SUVs. To package awd with the long inline 6 engines, they use a chain driven (in the SUVs) or gear driven (in later model cars) power take-off at the multi-clutch plate transfer case to send power to the front wheels. The front axles go through the sump in some applications, which means suspension travel is limited, as well as opportunity to lower the car. As pioneered by Audi, they use ABS sensors working in reverse to detect wheelspin and slow the spinning wheel, thus faking the open differential at either end of the car into sending power to wheels that actually do have grip.
<img src="http://bmwfinlandpinter01.ergointegration.no/bilde.asp?id=3428">
<img src="http://china5.nikkeibp.co.jp/china/image2005/01/050105bmw3.jpg">
In a Torsen based Audi the center differential is a fully mechanical unit most often used in rally cars and military vehicles. No electronics involved. Since the engine sits ahead of the front axle, the power take-off shaft and drive shafts are not in conflict with any other portions of the driveline. The latest version of Quattro in the B8 chassis of the A5, show that the engine sits further back than ever, with the transfer system even more compactly packaged.
<img src="http://www.mecanicavirtual.org/images-diferencial/audi-torsen-grande.jpg">
Approx 68% of power is sent to the rear wheels of a xDrive equipped vehicle, and the remainder to the front. This gives a more rwd type of dynamic. Good when plenty of grip is available, but prone to initial oversteer in really nasty weather. It takes a few fractions of a second for power to be routed from slipping wheels to gripping wheels. By starting with a 50/50 power distribution, there is inherently less dynamic instability in a traditional Quattro system, as there is usually less power shuffle.
The reason behind most manufacturers adoption of E-diffs is lower production costs by using existing parts rather than create new ones. It also lowers cost of maintenance since only brake pads see extra wear, not hard to replace limited slip clutches. Finally it is easy to integrate into ESP systems, and change the handling characteristics via programming rather than hardware changes.<ul><li><a href="http://www.gizmag.com/go/6575/">The new Quattro?</a></li></ul>
Old Jul 23, 2007 | 01:24 PM
GTA_Driver's Avatar
Tech Guru
Can't find the article now... will search when I get home.
