any timing belt DIY'ers here?
I'm picking up a very nice black on black 01' 2.7t in a few days, in need of a timing belt and a smog pump combination-valve(?).
Can anyone give some insight on these 2 items?
I searched, looks like most people take em in for the (timing belt) service.
-I'll be doing all repairs myself so I was just hoping there were a few shade-tree types round' here.
Thanks,
Marty
I thought there was a 2.7 timing belt writeup somewhere. <searches bookmarks>
Make sure you get a good quality tensioner, as I've heard here others have had the same problem.
I'd probably suggest just ordering the parts kit from ECS, as I used a local foreign auto place that guaranteed OEM quality, but weren't that great.
I ordered the timing belt tool kit from el paso tool on ebay. They were baum tools, and cost ~110 shipped.<ul><li><a href="http://cgi.ebay.com/ebaymotors/VW-Audi-3391-3242-Camshaft-Timing-Cam-Engine-Tools_W0QQcmdZViewItemQQcategoryZ35625QQihZ002QQit emZ120144974821">ebay cam tools</a></li></ul>
The nose of the car does NOT need to be torn all apart. Service position is far enough. It's crazy to do all that extra work.
Cam adjuster seals should always be done with the belt, as should cam seals and valve cover gaskets.
You should always use the timing belt tools. Unlike the older cars, cam timing is infinitely adjustable on the 30v; the cam sprocket is not keyed to the cam. It is impossible to properly adjust cam timing without the tools.
It helps to have someone with experience look over your shoulder, but the job is doable by someone with time, sense, and a little experience.
1. Remove the front bumper.
2. Remove the bumper mounts and screw the bolts from step 1 into one or the holes on each side.
3. Detach the upper radiator hose at the radiator.
4. Unbolt the radiator support and slide it forward on the longer bolts (from step 2).
This buys you 6 or so inches between the radiator and the front of the engine; more than enough room to do the job without disturbing the AC, wiring, headlights, etc.
2.8 is probably about 15-20 minutes easier of a job, I guess.
