Brakes... deal or no deal?
Anyone use the set linked below? I am not sure I need the SS lines, so maybe could be a bit less without that.
The other option I am thinking is the Hawk HPS pads from Tire Rack for ~$210 shipped and ~$241 for all 4 rotors from Audi dealership.. no shipping (plus maybe $50 for the fluid, etc). $500 for the whole set up about.
Any help or anyone who bought recently would be helpful. Gotta finally make the purchase (as well as TB, TBB, Plugs, etc coming up in the next couple weeks).<ul><li><a href="http://shop.achtuning.com/index.asp?PageAction=VIEWPROD&ProdID=1092">Cli ck for Brake Package</a></li></ul>
The minimum thickness depends on which type of brakes you have - for the HP2 rotors I believe the minimum thickness is 28 mm (they are 30 mm new).
As for rotors, IM (contrarian) O, worn rotors are better than new, inasmuch as rotors tend to wear true. Toward this end, key each of your rotors to its mating hub with center punch marks such that rotor to hub orientation is never lost, nor rotors ever mismatched to the wrong hub.
The unworn annular rings either side of the active rotor surface make for a most effective 4 wheel, 8 surface passive wear sensor system, when any one of them contacts a worn pad's backing plate. I always short out the active pad wear sensors at the pad side connector, eliminating that year of warning light.
