Avant suspension(?) noise
Old Jul 25, 2007 | 03:47 PM
Wild_Bill's Avatar
Default Avant suspension(?) noise
Car: 2003 A6 Avant...several months back (around 41k miles), started hearing an occasional, muffled, mild booming noise seemingly from the rear of the car. It's a booming, drum head positive-negative pressure type noise, not a rotational scrape, screech, rumble, etc. It seems perfectly in rhythm with vertical suspension movement, i.e, in synch with road surface..series of quick small booms on smooth roads, more pronounced booms on bad, uneven pavement. No tire or wheel issue...three brands of tires tried, no change. Wheels are round and not warped. One dealer tried another set of wheels, no change. F/R alignment is in spec, tires wearing evenly..Car has been thoroughly checked by two dealers cumulatively for about eight days, who found no wheel bearing issues, no loose parts, no bad CV joints, etc. Access panels in the interior wheel wells fit tight, spare is tight, nothing loose in that area.
Dealers are stumped.
It's getting louder, it's really annoying, and I'm getting frustrated. I can now hear a little of it as soon as the car stars moving...Any ideas? Since it seems in synch with vertical suspension movement, could it be a bushing or strut issue? Anything that can be lubricated?
Old Jul 25, 2007 | 03:56 PM
Press's Avatar
Fear the Miata!
the dealer is stumped....if they can hear it they should be able to isolate it and fix it
Old Jul 25, 2007 | 03:59 PM
Kris Hansen's Avatar
Head Cat Herder
25 Year Member
Default Odd. Must be something loose or broken.Exhaust hangers, sway bar links, coil springs..
upper shock mounts.. could be lots of things.
Old Jul 25, 2007 | 04:43 PM
Wild_Bill's Avatar
Default Re: the dealer is stumped....if they can hear it they should be able to isolate it and fix it
One tech "thinks" he heard it; the other really didn't. Thought it was normal road noise. Said he'd heard something similar before and maybe typical of tires with stiff sidewalls (had Pirelli p Zero Nero's at the time). They kept the car a couple of days and went over it anyway. But you're right, if they didn't EXACTLY hear it, you dont't know how far they went. Trouble is, if you haven't been driving the car, you don't have the before and after comparison. My passengers couldn't seem to hear anything on a 400 mile trip, but it drove me crazy. The car was dead quiet on the road until this started.
Old Jul 25, 2007 | 05:25 PM
Wild_Bill's Avatar
Default Re:
I asked them to check shock mounts, etc. They noticed a little exhaust rumble due to loose exhaust clamps, fixed those, but no change in the other noise.
Old Jul 25, 2007 | 05:59 PM
Press's Avatar
Fear the Miata!
that suxs for sure
Audishiva
A4 (B7 Platform) Discussion
Oct 25, 2015 07:20 PM
audiRenner
Audi Original "S" Cars
9
Oct 1, 2008 05:30 PM
hcj
20
May 17, 2007 01:15 PM
Synmag
Audi allroad
Oct 13, 2005 01:30 PM
faust92
Sep 9, 2002 09:15 AM
