turning signal problem for a6 2.8 quattro 2000, please help
What you guys would suspect? is it because of the fuse? or the reley? or something else?
since passingerside turning signal work- blink-, i don't know what is the problem..
My car has turned out it has tons of problems..
For the additional information, the frong driver-side fog light also does not work, but passinger side fog light work..
Do you guys think it has something to do with turning signal either? I don't know how to replace the fog light bulb, so i could not try to replace it, but i replaced the turning signal bulb, and it still does not work.
So... please help me to find out what i sould replace?
Thank you so much for your help
i don't think it's bulb problem.. one signal does work, so is it possilbe that it is fuse problem?
just a guess, I could be wrong, hopefully.
Anyway, what is the light harness? Except the driver-side fog light, and turning signal, everylights work fine..
And the turning signal also turn on, but not blinking when i turn the signal..
Do you have any idea?
Thanks for your replying.
So how much did you pay for the relay? if i do this in the local repair shop, how much should i expect? can you get me a picture?
I wish i'm good at car, this car broght me a lot of work.. - -' mirror controller, fog light, turning signal, wheel cap...
I should have checked the car more carefully before i bought this..
Thanks for your help...
