washer fluid resevoir leaking...has anyone tired pulling it and using
Old Jul 28, 2007 | 11:39 AM
LeftLaneA6's Avatar
Default washer fluid resevoir leaking...has anyone tired pulling it and using
a silicone caulk (or similar) to repair Vs. replace? Did it work?
Old Jul 28, 2007 | 11:47 AM
Pete RD's Avatar
Default Are you sure the reservoir is leaking? The pumps can leak as well as
the headlight washers. Where is the source of the fluid loss?
HTH
Old Jul 28, 2007 | 01:22 PM
4Driver4's Avatar
Tech Guru
Tech Guru
2nd. Remove washer pump for headlights and jam a tire valve stem in its place.
Old Jul 29, 2007 | 04:25 AM
Reifle's Avatar
Default Recently had to replace the pumps - that is where mine was leaking from...
I had to take the whole left front fender liner and such all out - real PIA!. Took the pumps apart and they were so badly corroded I had to replace the pumps. Everything has new electrical fittings and again so much extra work to get it done. Put it all together and now all is good!
weberic
Rocky Mountain Discussion
Dec 29, 2008 04:52 PM
Yanivic
Jul 10, 2006 08:05 AM
WPGQuattro
Feb 21, 2006 08:15 AM
Nic8462
Jul 9, 2004 09:51 PM
marcp
Jan 30, 2003 04:30 PM
