fan clutch install needs removing front end??!!
Old Jul 29, 2007 | 06:07 AM
chadi7's Avatar
New Member
Default fan clutch install needs removing front end??!!
audi a6 98 2.8l. I have an overheating problem; spilled coolant as I was parking; changed fan clutch once but problem not solved; the dealer claims the fan clutch still doesn't work and wants to charge 550$ to install a new one, claiming they have to remove the whole front to get to it !!! Is that true??? I know to get to the TB you have to, but fan clutch is just so accessible, and the mechanic who did it first time didn't remove the front end. Who's right???
Old Jul 29, 2007 | 06:14 AM
newjerseyshorel's Avatar
New Member
dealer is just being a dealer... i'm sure you can remove it by reaching, one nut, 3 hex bolts
Old Jul 29, 2007 | 06:37 AM
4Driver4's Avatar
Tech Guru
Tech Guru
Default You don't have to remove the whole front end. Service position should be far enough.
$550 sounds reasonable from a dealer.
Old Jul 29, 2007 | 07:55 AM
AudiForYou's 2.7T's Avatar
Default No you can't. You can unbolt it, but it won't come out of it's nest in the radiator support...
... unless you move the support forward.
A8AWD
Mar 23, 2007 01:52 PM
shostang
Oct 29, 2006 01:35 AM
Tourette(AFC2.812v)
12v V6 Discussion
Feb 23, 2005 08:39 AM
blodi
May 20, 2004 09:19 PM
0700
Jun 8, 2002 09:36 PM
