5 volt bus available ???
Old Jul 29, 2007 | 09:59 AM
JohnSr's Avatar
New Member
Default 5 volt bus available ???
I am a new owner of a 2002 A6 quattro sedan. I don't have the factory navigation system and would like to install my aftermarket GPS system which requires a 5 volt power supply. Is there a way to wire it in to the car's standard electrical system? I would rather not use a cigaret lighter adapter. Thanks in advance for any advice or pointers to other resources that might be able to help.
Old Jul 29, 2007 | 10:56 AM
newjerseyshorel's Avatar
New Member
you could hide the cigarette lighter behind the dash and solder 12v to it
Old Jul 29, 2007 | 12:56 PM
Chapaevsk2.7T6spd's Avatar
Default I would use an LM7805
and build this simple regulator, assuming your GPS system won't draw more than an amp.<ul><li><a href="http://www.eidusa.com/Electronics_Voltage_Regulator.htm">click for link</a></li></ul>
Old Jul 29, 2007 | 05:10 PM
A6 4.2/S4 Portlnd OR's Avatar
Default Easier Approach
<ul><li><a href="http://www.audiotstation.com/forum/showthread.php?t=25715&amp;highlight=USB+battery+p ack+cheap">clicky</a></li></ul>
Old Jul 29, 2007 | 09:00 PM
BrianG's Avatar
Default It's a little more complicated than that....
An LM7805 can do an amp of current before it current limits to protect itself. However, since the input voltage is 12V from the battery, the part will be dropping 7V (12V input minus 5V output), and thus, its power dissipation will be equal to 7V multiplied by the current drawn by the load (the radar detector, etc). Since the LM7805 really shouldn't be asked to dissipate more than 1 Watt without a heatsink in an enclosed area with no airflow, the most current it can supply under these conditions would be equal to 1 Watt / 7 Volts = 140 milliamps. If you try to draw more current, the LM7805 will overheat and go into thermal shutdown, so you shouldn't start a fire, but it won't work too well.
Old Jul 29, 2007 | 09:04 PM
BrianG's Avatar
Default I wouldn't eliminate the input capacitor as your link suggests.
The link from Chapaevsk2.7T6sp is a better approach. Too much inductance on the input pin of the LM7805 without a local capacitor can cause problems with the LM7805's operation.
Old Jul 30, 2007 | 03:19 AM
Good point...
awdinut
May 21, 2018 10:57 AM
S6Express
A6 (C7 Platform) Discussion
18
Jul 20, 2013 12:59 PM
TerryTCL
Oct 18, 2006 11:37 AM
2Cr4ck2
Oct 27, 2003 03:40 PM
Kirath ¾-B0§t0n
Sep 23, 2001 08:32 PM
