stupid spark plugs
Old Jul 29, 2007 | 08:27 PM
JimmyC83's Avatar
Default stupid spark plugs
greg just helped me get some new sparks in the car finally today, via 3 flashlights and mosquitos..lol
a lil less turbo lag...and better mileage for 12$ okay!
but we are using NGK BKR7E's in the car now...
(copper)
does anyone know how long i can go on these max? according to and in real life recommended mileage
stfa yields like.... 2 months/5000-7500 miles
and moreover...what are those ones that have are made of, erm platinum but have a copper core alternative properties rated at 50K miles and 20$ a plug? absolutely hated the "closest" coilpack to the headlights on each side...(almost seated behind the Y pipe) oh and the "wire hanger" clip to the airbox too...grr
Old Jul 29, 2007 | 08:41 PM
LuvnhatemyA6's Avatar
Member
I favour the OEM platinums. Got a set of 6 for $40 on e-bay. Lifetime at least 50K miles.
Old Jul 29, 2007 | 08:42 PM
Member
NGK PFR6Q
Old Jul 29, 2007 | 09:21 PM
LEH82's Avatar
Junior Member
2nd $9.95 each www.partsamerica.com free shipping and no tax depending on where you live.
Old Jul 30, 2007 | 03:48 AM
audikillsbmw's Avatar
Member
Always complaining about something... :P
Old Jul 30, 2007 | 05:32 AM
reapersA6's Avatar
New Member
Default I went with the platinum twin tips - work great
I don't know what all the fuss is about with people and spark plugs. The day somebody can show me a 5 h.p. increase or decrease based on some plugs is the day I consider their testimony on how awesome the new platinum plus 4's, or Audi factory plugs, or copper cored/platinum tipped ones are. I spent a whopping $3 a plug and am happy as a clam. Got rid of my hesitation, car runs smooth and sweet now.
Old Jul 30, 2007 | 05:45 AM
GDawgA4's Avatar
Default Bosch F5DPOR are the ones I told you about last night. We put in BKR6Es =P
And you need a new air filter buddy ;-)
Old Jul 30, 2007 | 05:49 AM
GDawgA4's Avatar
Default Copper plugs lowers your EGT temps...its not all about HP gain or loss but
better performance overall.
"Now many would ask "Why use Copper when they don't last over 5k???" Well first of all, before my explanation, simply switching from platinums to standard coppers will lower your EGT temps anywhere from 30-40C Degrees!...read on:"
"Comment: The plugs heat range and the thermal conductivity of the plug center electrode will determine the operating temp of the spark plug only. The spark plug's ability to influence EGTs is at best, secondary to the single ground on the copper plug igniting a larger flame front initially, resulting in combustion of the end gas fraction occurring earlier in crank angle degrees before the exhaust valve opens.
Multiple ground electrode plugs are not the best choice for a performance application primarily due to the additional grounds shielding the spark from as much ignitable fuel/air mixture as possible. In addition, some combustion chamber shapes can be sensitive to the angular position of just one ground 'trode. (and that sensitivity can vary with cylinder pressure and air/fuel mixture turbulence)
That is why "plug indexing" is used in many drag and track competition engines."
 Pouria Savadkouei
 Michael S. Palmer
Old Jul 30, 2007 | 08:38 AM
JimmyC83's Avatar
Default without complaining, life would be boring
oh and yeah, life would be more boring too if i had already posted #4 and you not wondering what it is..haha
Old Jul 30, 2007 | 08:41 AM
JimmyC83's Avatar
Default i wasn't complaining about the spark plugs. i was complaining about the
location of the closest coilpack to the Y-pipe on each side....and since i have an 01.5, the coilpacks are not clip in's...they are bolt on's (2 annoying little wasping bolts) on each end that slow the process down alot more considering its very easy to drop it and lose it inside the engine bay =)
