whats a safe way to trigger a cel???
Old Jul 30, 2007 | 06:49 PM
newjerseyshorel's Avatar
New Member
Default whats a safe way to trigger a cel???
How could I trigger a CEL safely to check to see if someone had tinkered with the light in the dash?
Vagcom is giving me a intermittent CPS signal error, and I'm kinda wondering why I don't have a CEL for it.
Old Jul 30, 2007 | 07:16 PM
MP4.2+6.0's Avatar
Tech Guru
Disconnect vac lines underhood, especially the sec. air injection ones
Old Jul 31, 2007 | 03:59 AM
Chaddy's Avatar
Junior Member
Default All instrument lights should come on briefly at start-up (called the "bulb check"). Also, not all
error codes cause the CEL to illuminate - intermittent connections, small evap leaks, etc can cause stored codes but no CEL.
When you start the engine, watch the instrument cluster for the amber-colored picture of an engine block w/ a lightening bolt - I believe that's what it looks like, IIRC.
Old Jul 31, 2007 | 04:00 AM
4Driver4's Avatar
Tech Guru
Tech Guru
Unplug an injector or the evaporator valve for a few seconds with the engine running.
Old Jul 31, 2007 | 04:27 AM
Kris Hansen's Avatar
Head Cat Herder
25 Year Member
You don't always get the MIL for intermittent faults.
Old Jul 31, 2007 | 05:49 AM
S4_Cinci (I S'edTFA)'s Avatar
Member
Default Also, simply turn the key to the "On" position without starting the car and all warning lights will
come on. It is possible to have codes stored w/o the CEL/MIL being illuminated - things like random multiple misfires will only cause MIL if there are enough of them. BTDT.
Old Jul 31, 2007 | 06:26 AM
All Wheel Driver's Avatar
Rest In Peace
unscrew the gas cap and start the car.
Rudy H
Mar 1, 2009 10:54 AM
voxsmj
NY / NJ / CT Discussion
Jan 21, 2009 09:03 AM
jdudlak
Audi A3 / S3 / RS 3
Aug 27, 2007 03:46 PM
BoneStockS4
Oct 13, 2005 11:31 AM
ordare
Jul 20, 2002 06:19 AM
