Anybody's A6 makes humming noise after its parked and turned off??
Old Jul 31, 2007 | 07:32 AM
Jonez's Avatar
Default Anybody's A6 makes humming noise after its parked and turned off??
<center><img src="http://pictureposter.audiworld.com/106705/a6_graphic_copy2.1.jpg"></center><p>this is weird. after driving all day, when i turn my A6 off and get out, i hear a "mmmmmmm" humming noise coming from the rear passenger corner. sometimes it has intervals like "mmmmm,mmmm,mmmm" and sometimes its just one continuous humm. i started the car up and let it run for 20-30 minutes and turned it off, with no humm. it only happens when im driving. anybody know what this is?
Old Jul 31, 2007 | 07:42 AM
bac2h's Avatar
Ace Ventura
It's gas tank pressure relief...loosen your gas cap and it goes away..remember to re-tighten!!
Old Jul 31, 2007 | 07:43 AM
Jonez's Avatar
Default Re: It's gas tank pressure relief...loosen your gas cap and it goes away..remember to re-tighten!!
i'll try that. thanks for the tip.
Old Jul 31, 2007 | 07:45 AM
02 Silver Arrow's Avatar
It doesn't know the words
Old Jul 31, 2007 | 07:56 AM
nemesisa6's Avatar
ahhaha. I think its a sigh of relief.
Rocky-in-Connecticut's Avatar
Default you don't haveto loosen your gas cap..normal EVAP system behavior
in fact, you are defeating the purpose of the EVAP system is you loosen your gas cap to stop the noise.
Old Jul 31, 2007 | 09:33 AM
Smokey Bear's Avatar
Member
lmao.... "Finally done with this newb driver" &lt;/car's thoughts&gt;
Old Jul 31, 2007 | 09:56 AM
bac2h's Avatar
Ace Ventura
If you want the noise to go away loosen the cap...does not hurt EVAP system..
 Pouria Savadkouei
 Michael S. Palmer
Old Jul 31, 2007 | 10:05 AM
Whitjr's Avatar
It's the bass line to the last song on the radio.....
Old Jul 31, 2007 | 10:16 AM
Default the purpose of the EVAP system is to prevent fuel vapors from escaping...
..into the atmosphere. Nowhere did I say it would hurt the EVAP system to loosen the gas cap.
But it will defeat the purpose of the EVAP system if you release the gas cap which will enable fuel vapors to escape into the atmosphere.
