2001 A6 Driver side window is acting up.....
Old Jul 31, 2007 | 10:24 AM
ALA1080's Avatar
New Member
Default 2001 A6 Driver side window is acting up.....
When I put the window down all the way, then try to put it back up again it will stall halfway and then I have to pull it up the rest of the way. I brought it to a shop and the guy quoted me $350 to fix motor. Does that sound right????
Please help me!
Old Jul 31, 2007 | 10:51 AM
Press's Avatar
Fear the Miata!
do a search for window guides....pretty inexpensive fix
Old Jul 31, 2007 | 12:16 PM
ip4me's Avatar
New Member
Default It's not the motor . . .
Like Press said, the problem is probably broken window guides. The guides themselves are little plastic parts and fairly inexpensive. However, you have to take the door apart and the window frame out to get at them. Labor costs can therefore be fairly high.
You can easily do it yourself in about an hour, but you must be patient. There are lots of different connectors and fasteners to remove. There are several articles re window guides in the linked Stoneys FAQ under "Service, other and general."<ul><li><a href="http://sonolithics.com/files/a6_links.html">Stoney's</a></li></ul>
Old Jul 31, 2007 | 12:44 PM
Scotts6's Avatar
Default window guides maybe?
<center><img src="http://pictureposter.audiworld.com/53402/mvc-002f.jpg"></center><p>
Old Jul 31, 2007 | 01:41 PM
JimmyC83's Avatar
mines doing this too, but it only happens when its hot out or reaaaally cold contractions/expanding
Old Jul 31, 2007 | 06:02 PM
Sweeney's Avatar
Default Mine did this last winter...
The window would start upward then reverse an drop down. It was, of course, 5F and snowing hard.
Sprayed some silicone lube down the tracks and it hasn't done it since.
Old Jul 31, 2007 | 07:19 PM
Esquire6's Avatar
Is it a DIY fix?
Old Aug 1, 2007 | 06:49 PM
MP4.2+6.0's Avatar
Tech Guru
Temp. related differences are another indicator it is the guides from my experience too.
 Pouria Savadkouei
 Michael S. Palmer
Old Aug 4, 2007 | 06:24 PM
Esquire6's Avatar
I guess NOT!
mike1305
A6 (C7 Platform) Discussion
Jun 13, 2016 06:02 AM
AudiJinkins
10
Aug 20, 2013 01:12 PM
KillA6
Aug 25, 2005 07:50 AM
nightwalks
Jun 6, 2004 07:08 AM
