Weird power drivers seat issue (long)
Old Sep 12, 2007 | 11:20 AM
CapeCodAudi's Avatar
Default Weird power drivers seat issue (long)
I was locking my car today and noticed that my windows wouldn't work and sunroof wouldnt close. Then noticed that my drivers seat would only go back and forth but not up and down and the back wouldn't move. I looked at fuses and number 14 was blown. Replaced i but it still blew out right away. When i wasn't on the seat it moved perfect. Vag-Com is giving codes of a drivers seat sensor ground issue and low voltage. I also noticed the interior lights only work when i push the seat buttom up and down as long as i'm not sitting in the seat which also let me put the windows up. I assume there is a short in the seat wiring which is grounding the lighting system and blowing the fuse. Has anyone experienced this before or direct me on what to look for. Also vag com sent a code saying it turned of the central locking to, probably because of the short. HELP!!!
Old Sep 12, 2007 | 11:42 AM
LuvnhatemyA6's Avatar
Member
Default Yes, you have a short in the seat.
Most common cause is the lumbar support mechanism chafing the wiring to the rear footwell light. You can disconnect the connector under the seat to the rear footwell light, may stop the fuse blowing.
Old Sep 12, 2007 | 11:52 AM
Default Re: Yes, you have a short in the seat.
<center><img src="http://pictureposter.audiworld.com/122085/seat_removal_4.jpg"></center><p>I removed the top harness from this picture.. it only has two wires... what does this go to?? Anyone know??? First arrow under the word CLIPS only has 2 wires.
Old Sep 12, 2007 | 12:08 PM
Member
Default I don't know. Disconnect it, if the footwell light stops working , there's your answer.
BTW, this topic has been discussed many times. Search on fuse 14.
https://forums.audiworld.com/a6/msgs/659302.phtml
Old Sep 12, 2007 | 12:17 PM
Default Re: I don't know. Disconnect it, if the footwell light stops working , there's your answer.
It stopped my seat from going backwards and the seat back from going back and forth.. gonna be fun
Old Sep 12, 2007 | 12:46 PM
mpw's Avatar
mpw
Default The top 2 wire connector is for the rear footwell light.
I don't know how that stopped your seat from moving!
Old Sep 12, 2007 | 12:49 PM
Default It is weird... time to pull the seat out I guess and look for the
wires that are torn open!! What a pain in da @#$@
Old Sep 12, 2007 | 02:04 PM
Default UPDATE:top 2 wire connector is for the rear footwell light.
Thats the problem... seat functions all work for now.. found one connector not all the way back in! Is it hard to find that wire and where it split?
 Pouria Savadkouei
 Michael S. Palmer
Old Sep 12, 2007 | 02:19 PM
Member
Default Well, it pains me to suggest this.. but I know one person just permanently unplugged the light.
I mean it's not as if the rear footwell light is essential, is it?
Alternatively, it took me 4 dealer visits, a lumbar mechanism, and $1000 to fix mine. Wish I had just unplugged the light.
Old Sep 12, 2007 | 03:06 PM
Default Thank you for Audiworld no trip to the Audi Stealers(dealer)
Might make a new wire connection from the harness i unplugged to the light.. a little OCD and I hate when things aren't working
