Leaving for work, I put the car in 1st gear , go a short distance and let off the gas...the car
Old Sep 13, 2007 | 05:01 AM
audi2.7audi's Avatar
Default Leaving for work, I put the car in 1st gear , go a short distance and let off the gas...the car
engine stuttered/stalled a bit when i got off the gas pedal..... 2nd gear did a little....but once I got to 3rd , etc it was fine.... later in the ride, after getting of the highway, it was fine in 1st and 2nd.... is this a clutch going bad ?
Old Sep 13, 2007 | 05:05 AM
SNAFU 4's Avatar
Sounds more like a boost leak or something. The clutch should not make the engine shutter.
Old Sep 13, 2007 | 06:39 AM
4Driver4's Avatar
Tech Guru
Tech Guru
Or a problem with the BPV's.
Old Sep 13, 2007 | 07:37 AM
How do I test a BPV to see if this is my problem? tx
Old Sep 13, 2007 | 08:58 AM
Just Me's Avatar
Tech Guru
Tech Guru
not clutch, its a boost or mixtue issue - cant say more
Old Sep 13, 2007 | 12:17 PM
SNAFU 4's Avatar
Default First eyeball the TBB to check for rips or tears (sometimes underneath) and the DV's too.
I have not personally checked with any tools before, but I think that is the usual suspect for a boost leak (assuming no other issues, check engine light, etc).
internets
May 7, 2009 10:28 AM
b5audi(t)
Mar 24, 2005 01:17 PM
mnemonic
Nov 15, 2004 01:10 PM
SternkrafTT
Feb 17, 2004 07:11 AM
MNblackS4
Jul 29, 2002 10:03 AM
