Low coolant level
where can I purchsde the Audi coolant from?
Thanks
If it is low coolant, then yes, you can overheat. My low coolant problem went away after my shop swapped out the cap on the coolant tank.
Also, if the gauge shoots way up it could be the sensor, or it could be you frying the engine. Stop, don't drive and inspect.
You could get the coolant from Audi or VW... water will work fine in a pinch (if you plan on flushing anyway).
Also, definitely elaborate on which warning light (low coolant or high temp) and what was your water and oil temp at during that time....
