Need correct offset for 2000 A6 2.7t, please.
Old Sep 16, 2007 | 09:16 AM
2.7Thunder's Avatar
Old Sep 16, 2007 | 09:18 AM
2.7Thunder's Avatar
Re: Need correct wheel offset for 2000 A6 2.7t, please.
Old Sep 16, 2007 | 11:24 AM
SNAFU 4's Avatar
Old Sep 16, 2007 | 11:42 AM
audikillsbmw's Avatar
Member
Old Sep 16, 2007 | 05:22 PM
absolutcq20v's Avatar
Old Sep 16, 2007 | 07:19 PM
MikekiM@PureMS's Avatar
Former Vendor
Offset is measured only relative to wheel width. What width are you running?
Old Sep 16, 2007 | 10:17 PM
2.7Thunder's Avatar
Default Re: Offset is measured only relative to wheel width. What width are you running?
My present wheels are 8.5" and the tires are 225x35x18
Old Sep 17, 2007 | 05:05 AM
Boston Driver's Avatar
AudiWorld Expert
 Pouria Savadkouei
 Michael S. Palmer
Old Sep 17, 2007 | 05:49 AM
AudiWorld Expert
Default I'll give you the factory specs...
16x7" ET45 offset for either wheel ofered on the 2000 2.7T (the twin 6-spoke wheels that came with a sport package or the stock 5-spoke wheels). In 2001 (later in the model year) the sport package wheel was changed to the BBS-style which was 17x7.5" ET43 offset.
Again, offset alone does not determine if a wheel will fit. The shape of the spoke contributes to fitment as well.
Old Sep 17, 2007 | 06:30 AM
Former Vendor
Default With that width an offset of 35 is a good fit.
However as Boston driver noted above, on the 2.7T you have bigger than average calipers, so offset alone won't determine if the wheels will fit.
There's no absolutely required offset measurement for everyone. ET35 is just a rough estimate of what will fit on the A6 2.7T. You can probably go as low as ET30, or as high as around ET40 (depending on the clearance of the brake caliper).
TheXMan14
Apr 10, 2018 02:10 PM
RangeR BoB
Jan 22, 2007 08:47 AM
darkstyle
Feb 22, 2006 07:09 PM
saabSean
May 13, 2003 11:21 AM
mrmikepa
Jun 20, 2001 12:31 PM
