Fair price for new alternator?
The Valeo or the Bosch will work, but they have different pulleys on the front. If the alternator you buy has a pulley on it, no problem. But if you have to reuse your existing pulley, the alternator needs to match the unit you have now. Be careful what you buy. The dealer stuff is stupidly expensive, but the cheapo Autozone stuff is garbage (STFA on the B5 forum). I bought an aftermarket unit for $200 that has worked for 50k+ miles.
You will need to put the nose into service position, but you will not need to remove the timing belt. However, since there is some labor overlap, consider doing a complete belt service if you are close to a timing belt change.
What codes are you finding in the ECU? Have you tried a new ignition switch?
What happens if you left foot brake and use your right foot to try to hold the revs up?
