Won't start!
Old Sep 17, 2007 | 03:07 PM
Avant Eric's Avatar
Default Won't start!
From what I've came across searching, I'm thinking a likely place to start is with the ignition switch.
Battery is fine, starts my 1966 Mustang with no problem. No corrosion on the battery posts, there's just nothing but the usual clicks when I turn the key to start.
So, does anyone know if there is a way to test the switch without tearing it out? I'm assuming there is a starter solenoid somewhere along the line as well; anyone know where that is located? I'd like to test that too.
Any other ideas would be appreciated.
I also found a VW site that has some pictures of a replacement on a 1998 Jetta, link below. Has anyone tackled a switch replacement that could let me know if this is similar to my 1999 A6?
Thanks for any help,
Eric<ul><li><a href="http://forums.vwvortex.com/zerothread?id=3421753">98 Jetta switch replacement</a></li></ul>
Old Sep 17, 2007 | 03:37 PM
4Driver4's Avatar
Tech Guru
Tech Guru
Default Do some diagnostic work before you jump in and start replacing stuff.
It's very rare for a bad ignition switch to cause a no crank situation on these cars.
When you turn the key to the "start" position do you get power to the starter solenoid? If you jump the solenoid will the car start? Is the car in Park? Did you try in Neutral?
Plenty of things to check. Diagnose first, then fix. ;-)
Old Sep 17, 2007 | 03:52 PM
Avant Eric's Avatar
Default Right...
That's what I'd like to do, just don't know where anything is!
Is the solenoid remote someplace in the engine compartment, or is it attached directly to the starter?
Old Sep 17, 2007 | 03:57 PM
4Driver4's Avatar
Tech Guru
Tech Guru
On the starter. You need a Bentley or you'll be lost.
Old Sep 17, 2007 | 04:37 PM
Avant Eric's Avatar
Thanks, gotta find my Bently CD codes when I took it off my old computer.
nleusky
Audi Original "S" Cars
Feb 20, 2012 02:13 PM
|skolnick
13
Jun 4, 2009 05:27 AM
jbfiii
Oct 10, 2007 03:59 PM
qpower
Jun 20, 2006 10:47 AM
DCXninety
9
Jan 25, 2005 05:02 PM
