power steering problem
Old Sep 18, 2007 | 08:46 AM
cardiffkid's Avatar
Default power steering problem
Hi, Have a whine in the power steering. Got some fluid from Audi and brought the level up to where it should be. The whine is still there! Tried bleeding the air by turning the wheel back and forth, but no luck, still air coming up in the reservoir. Any ideas on getting it out? and then if that does not do it what does it take to change the pump? Ken
Old Sep 18, 2007 | 09:11 AM
BernieBenz's Avatar
Default Ken, If air in the reservoir, clean the reservoir's filter screen and check the reservoir...
to pump supply hose for leaks. Should be absolutely dry.
Old Sep 20, 2007 | 11:41 AM
NextMan's Avatar
New Member
Default Try filling above the MAX line.
I had a similair problem and added the fluid to MAX line in reservoir and still had the problem. I then added some more fluid near to the top and the problem was gone.
ledzepp2994
Apr 18, 2011 01:33 PM
pjp13
Jan 22, 2009 06:39 PM
cardiffkid
Sep 13, 2007 04:30 PM
SolidFish
May 27, 2006 01:39 AM
