Engine stalls on hard braking...
Old Sep 18, 2007 | 09:38 AM
GeoW97's Avatar
New Member
Default Engine stalls on hard braking...
I thought this was an electrical problem, since I can see the voltage meter drop toward 12 just before the car stops. But someone pointed out that if the car is stalling for any other reason, the voltage meter would drop also. I still suspect some short or open in the wiring, since if I brake hard I can see the voltage meter drop below 14 even if the car doesn't stall. But if anyone has any other thoughts on why my car, which runs perfectly at all other times, would stall on a hard brake downhill, lemme know...
Old Sep 18, 2007 | 10:03 AM
4Driver4's Avatar
Tech Guru
Tech Guru
Default I suggested that you pull codes. Have you been able to do that?
That's your first step.
Old Sep 18, 2007 | 10:09 AM
GeoW97's Avatar
New Member
Default Haven't seen the CEL light up; would there be codes in there anyway?
...I'll go get 'em read today if so...
Old Sep 18, 2007 | 10:10 AM
4Driver4's Avatar
Tech Guru
Tech Guru
Could be. The ECU can store codes without lighting. I'd check the trans too.
Old Sep 18, 2007 | 10:15 AM
4.2ballsack's Avatar
Default CHECK TRANNY FLUID LEVEL.
LOW FLUID LEVEL WILL CAUSE ENGINE TO STALL UNDER
BRAKING.
Old Sep 18, 2007 | 11:11 AM
donp's Avatar
Default Push in the clutch?
Hey. Someone had to suggest it.
Old Sep 18, 2007 | 11:17 AM
GeoW97's Avatar
New Member
Default Ha! Would 'twer there were such a thing on my car...
...it's a tiptronic so my wife can drive it if need be...
Old Sep 18, 2007 | 11:51 AM
donp's Avatar
Default When your car is shut off and has been sitting, do you reserve brake assist left?
A failing check valve in the vac brake booster can cause stalling under those conditions.
Car off and sitting for an hour or so. Press brake to floor a few times. It should be easy at first then by the 2nd or 3rd depression get difficult.
Does yours behave that way?
 Pouria Savadkouei
 Michael S. Palmer
Old Sep 18, 2007 | 01:25 PM
paulroad's Avatar
Tech Guru
Default the brake pedal switch is a double switch..
It activates the brake lights and "stalls" the ECU. This may be a good place to look. It is a low voltage switch.
Old Feb 12, 2024 | 02:47 PM
naps45's Avatar
BRAKING.
sorry to revive a >15 year old thread—-but can you give any additional info on this? I suspect my wife’s Audi tranny fluid level is low. I am getting weird surges or stalls coinciding with braking and on incline/declines, etc..
hayde_bre
Q7 MKII Discussion
17
Jan 10, 2018 07:44 AM
alibaba
Nov 18, 2009 03:18 PM
popdemonic
Audi Original "S" Cars
May 28, 2006 08:27 AM
quantz
Jan 16, 2005 04:45 PM
Levent
9
Apr 8, 2002 08:23 AM
