Fark...started car this AM
Old Sep 21, 2007 | 06:35 AM
OCDboy's Avatar
Default Fark...started car this AM
and the power steering pump was screeming at me. Quick inspection of the reservior revealed it was low. I added fluid and after a few minutes it quieted down.
I've been driving the car all week without a hint of the steering pump noise. Biggest concern is where did the fluid go? I've had some oil on the floor and hadn't had time to investigate (just some drips). I just assumed it was leaking from my new oil cooler connections (that I've verified) and not the power steering pump.
Two questions:
1) Are there any common leaks I should look for?
2) Has anyone experience a sudden failure of the pump?
Old Sep 21, 2007 | 06:59 AM
JimmyC83's Avatar
Default *raises hand* , same problem....1 week later... steering rack blew...1400-2000$ out the door.
make sure every day you have the same amount of fluid if you refill. took 5 days of 'quiet' no squeel steering to burst for me...
Old Sep 21, 2007 | 07:00 AM
OCDboy's Avatar
Default Are you kidding? I was so depressed I drove out to HPT and
instructed at their Touring Club school on Wednesday night! I was desperate for a fix!
Car is running well but tired...I need to rebuild the front brakes and pick up new rotors, tires are just about done. I pulled them off last night and decided if I had gone to RA, they most likely would not have made it through the two days. Amazing how much shorter their lifespan has been lately :-)
Old Sep 21, 2007 | 07:47 AM
BernieBenz's Avatar
Inattention to PM will eventually bite. Break out the crying towels!
Old Sep 21, 2007 | 07:50 AM
BernieBenz's Avatar
IMO, rack failure is unrelated to pump problems.
Old Sep 21, 2007 | 08:21 AM
LuvnhatemyA6's Avatar
Member
I had the same problem too
Old Sep 21, 2007 | 09:25 AM
OCDboy's Avatar
Default Are you suggesting I don't maintain my car?
OK...I didn't check the P/S fluid recently. But there <i>is</i> a reason I'm called OCDBoy!
Old Sep 21, 2007 | 10:27 AM
GDawgA4's Avatar
Check the steering rack boots and see if they're leaking.
 Pouria Savadkouei
 Michael S. Palmer
Old Sep 21, 2007 | 11:24 AM
Whitjr's Avatar
Ouch!
Old Sep 21, 2007 | 11:31 AM
Press's Avatar
Fear the Miata!
Default i would have been able to diagnose it at ra....8^)
keep us posted
