Damn. How do you depress the clips on the hazard switch/relay to remove it?
Old Sep 21, 2007 | 03:18 PM
audikillsbmw's Avatar
Member
Default Damn. How do you depress the clips on the hazard switch/relay to remove it?
I've gotten this far, and it pisses me off that I can't get it out of there :P
Old Sep 21, 2007 | 04:16 PM
Member
Anybody? : (
Old Sep 21, 2007 | 04:44 PM
yrk2.7t@curbside's Avatar
Try some needle nose pliers, or even a small screwdriver to pry it out
Old Sep 21, 2007 | 04:46 PM
Member
In what spot though?
Old Sep 21, 2007 | 05:06 PM
Grapeking's Avatar
25 Year Member
Default ....<ahem>...the BENTLEY (hint, hint) says the following
Removing:
1. Carefully pry off trim panel using flat screwdriver.
2. Pull switch all the way out and disconnect electrical connector.
That's all it says.
Old Sep 21, 2007 | 05:12 PM
Member
If that's all it says, then I'm glad I didn't pick it up :P
Old Sep 21, 2007 | 05:15 PM
Grapeking's Avatar
25 Year Member
heh...I knew there'd be some twisted logic coming back my way!
Old Sep 21, 2007 | 05:16 PM
Member
lol
 Pouria Savadkouei
 Michael S. Palmer
Old Sep 21, 2007 | 05:19 PM
Grapeking's Avatar
25 Year Member
Default OK amigo - check this out - now you can't say I nver did anything for you : P
Check out the picture here and you'll see what you need to know.....<ul><li><a href="https://www.audiworld.com/tech/elec160.shtml">You'll be glad you clicked this link!!</a></li></ul>
Old Sep 21, 2007 | 05:27 PM
Member
That still doesn't show where to pry. I'll just go out and try it again..
