Worn Front Tires
Old Sep 23, 2007 | 05:32 AM
IW's Avatar
IW
Default Worn Front Tires
Wow, I just drove my Wife's 2004 A6 2.7T, 40K on Michelins, and it was terrible. It pulled to the left like crazy and sounded terrible. Took it to the tire shop and they scared me to death. The inside of both front tires were through the cords. What the heck caused the inside of the tires to wear that bad? Alignment? Tie rod ends? Or just bad tires? Michelins. Replaced tires with Bridgestones and all is well. Now has a slight pull to the right.
Ivan
Old Sep 23, 2007 | 06:05 AM
Just Me's Avatar
Tech Guru
Tech Guru
Default Sounds like alignment.
You didn't say which michelins, but I have found that Michelin overall makes the best quality tire on the market. Abnormal wear would only be the fault of the tire if it deformed badly, whcih I doubt it did.
Sounds like you either have too much negative camber or some loose suspension components.
Did you have the alignment checked and all the components checked for play?
Bear in mind, 40k is phenomenal on any even remotely performance oriented tire.
Grant
Old Sep 23, 2007 | 11:39 PM
LEH82's Avatar
Junior Member
Default i have the same problem but only about 10k on my tires and the front have severe wear in the insides
as well. i was told by mech that my tie rods needed to be replaced and most likely the control arms too.
Old Sep 24, 2007 | 05:54 AM
InTTruder's Avatar
AudiWorld Awesome User
Alignment, either toe or camber.
Old Sep 24, 2007 | 09:06 AM
Just Me's Avatar
Tech Guru
Tech Guru
Default Either alignment or worn parts (which let alignment stray). Not a normal circumstance
..for these cars. They wear the fronts fast, but quite evenly. Really hard driving wears the OUTSIDE, not the inside, generally.
Grant
Old Sep 24, 2007 | 10:25 AM
bman33's Avatar
New Member
Default Re: Worn Front Tires
If both front tires show inside wear, it is caused by too much negative camber.
http://en.wikipedia.org/wiki/Camber_angle
This could be fixed with a simple front end alignment, or could be caused by worn bushings, which will be more expensive.
Before you get new tires, take the car to a reputable alignment shop and have them diagnose the issue.
Old Sep 25, 2007 | 06:19 AM
IW's Avatar
IW
Default Re: Worn Front Tires, Epilog
Dealer says it was just needing alignment. Get it back today.
Next week timing belt. Crap!
Old Sep 25, 2007 | 07:04 PM
InTTruder's Avatar
Default Good news, bad news, good news:
You didn't "discover" the TB had failed!
 Pouria Savadkouei
 Michael S. Palmer
jaydubyagee
Suspension Tuning Discussion
Nov 30, 2006 07:06 AM
94' Pearl 90QS
11
Apr 8, 2006 09:00 PM
Silver Coupe
Jun 20, 2003 09:20 AM
cdnA4
Sep 12, 2002 11:39 AM
BeetleB
Oct 26, 2000 04:43 AM
