Has anyone's sliding sunroof sunshade broken?
Old Sep 24, 2007 | 03:18 PM
btruby's Avatar
Default Has anyone's sliding sunroof sunshade broken?
Mine did something yesterday when I was opening the sunroof. It got about halfway open, then popped.
The front clips broke, but the sunshade is attached in the back. The sunshade gets pushed way back, and prevents the sunroof from opening.
So how does the sunshade come off? I looked in my Bentley, but I couldnt make sense of it.
Old Sep 24, 2007 | 03:36 PM
Nate (ETKA+Scumbag)'s Avatar
Keeper of the Cash
Tech Guru
Not cool. You have to drop your headliner to do the repair.
Old Sep 24, 2007 | 04:52 PM
Boston Driver's Avatar
AudiWorld Expert
Default Actually, you can access the sunshade from above without dropping the headliner...
as long as you can tilt the sunroof UP and see the torx bolts on the side.
The Bentley did not have very clear instructions for removing the shade, but after some tinkering, I figured it out.
Here it goes:
1) Tilt UP the sunroof
2) Remove the plastic rail caps on each side of the sunroof (sorry no picture)
3) Look for the torx bolts pictured below and remove (three on each side, I cannot recall the size):
<img src="http://img.photobucket.com/albums/v739/hliu55/alcantara/Sunroof_2.jpg">
4) From outside the car, lift the glass panel up and out, find a safe place to store the glass panel
5) Looking from above, look for the philips screws that hold the clips for the shade panel. In the picture below, you can see the philips head screws securing small rectangular tabs...
<img src="http://img.photobucket.com/albums/v739/hliu55/alcantara/Sunroof_3.jpg">
6) once the screws are out, you should be able to free up the shade, reseat it in the rails, then reinstall the screws for the shade's tabs, the glass panel and torx bolts, and the plastic rail caps.
Old Sep 24, 2007 | 05:51 PM
btruby's Avatar
Default Thanks BD. I just hope the plastic clips didnt break.
I'm glad that you think the Bentley is confusing too.... I looked at it for 30 minutes.
Old Sep 24, 2007 | 07:59 PM
AudiWorld Expert
Default I could not locate the clips in the ETKA...
...you might need to reach out to Carson at Riverside for some help on that part number.
c99028b
Auto Detailing Discussion
Jun 27, 2011 04:06 PM
Philhawtin
Jun 22, 2011 09:00 AM
c4S6
Audi Original "S" Cars
May 22, 2007 11:27 AM
SchwarzS6
Nov 6, 2006 07:08 AM
