Anyone interested in a set of Black Sport Seats?
I hate to go against the rules and make a post like this but my transmission blew this morning and I need to gather some cash to fix it ASAP.
Email is jrstudley@comcast.net
I'm so distraught that I can barely type right now.
Are you sure you don't mean throughout bearing? Can you determine if the clutch fork and master cylinder are actually functioning?
The pilot bearing could be seized but I haven't heard of that happening before on this transmission. But it would shift fine when the motor is off.
I was bit by a bent shift fork and mushroomed splines on 1st/2nd & 3rd gear clusters. I have a nice pile of gears on my shelf to prove it. When it happened, I was horsing around missed third gear...in a blink of a bad shift the damage was done.
Now, I did get the shifting working by forcing the gears to shift with the motor off. It was very disconcerting to force the gears in and out. This will work the mushroom off the gear splines and eventually it will shift. I did get the car drivable again but it was so annoying I finally pulled the tranny and had it rebuilt.
If I had it to do over I'd buy the Stasis transmission. It comes with the 4:1 center differential for $2899. That sounds like a lot, but I believe that is the ticket.
Like Kris said, I'm sure a group can help out on R&R'ing the transmission.
I may be way off, but it's just my opinion...your milage may vary!
