Can someone tell me what these are.....
Old Sep 25, 2007 | 02:08 PM
NORCAL 4.2 A6's Avatar
Default Can someone tell me what these are.....
<center><img src="http://pictureposter.audiworld.com/122886/top.jpg"></center><p>1st pic is on the back top of motor and 2nd pic is located on the left front end of passenger side beneath the car. Sorry for the bad description.
The pic is looking from the ground up.
<img src="http://pictureposter.audiworld.com/122886/air.jpg">
What are the functions? I believe they have something to do with cold start up? Would these cause any of the issues I have been having during normal operating temperature? Slight ping and surging only when motor is warm...does not happen when motor is cold. TIA.
Oh BTW how tough to replace knock sensors on 4.2?
Old Sep 25, 2007 | 02:31 PM
Edd W's Avatar
Default Not sure but they look like a control valve to balance a pressure differential.....
such as when the aux air pump is running?
On the knock sensors, they virtually never fail so I would say they are unlikely to be your hot running problem, more likely the wrong plugs or the mixture is too lean. O2 sensors or MAF?
Old Sep 25, 2007 | 06:00 PM
audikillsbmw's Avatar
Member
Default Pic #2 is the air pump. As far as knock sensors go, they are on top
of the intake manifold (under the main cosmetic cover, if you still have it.) I'm not sure how they are wired in though..
isyantec
Sep 5, 2008 02:05 PM
audikillsbmw
12
May 22, 2008 09:51 AM
virtuapete
12v V6 Discussion
10
Oct 5, 2005 08:39 PM
quattro90S6
12v V6 Discussion
10
Dec 3, 2003 04:42 AM
blk18tq
Jan 2, 2002 09:30 PM
