Piggy pipes - I've STFA, other than cost what are the potential...
Old Sep 25, 2007 | 04:32 PM
boostbuddy's Avatar
Default Piggy pipes - I've STFA, other than cost what are the potential...
drawbacks to doing this mod? What can I expect to pay for the install at a good Audi enthusiast shop?
Any tips to make sure the mod works properly?
From what I can tell it seems like a good alternative to full cat back exhaust. Should I also remove resonators - is it a perforamcne or mostly sound change?
Thanks
Old Sep 25, 2007 | 05:35 PM
LEH82's Avatar
Junior Member
lots of power, turbo's don't need any back pressure the less the better i believe
Old Sep 25, 2007 | 05:39 PM
TGK's Avatar
TGK
Default Re: Piggy pipes - I've STFA, other than cost what are the potential...
Loud! I assume....All I have are Magnaflow rear exhausts and its annoying at times! I wanted to do the piggies, but not anymore.
Old Sep 26, 2007 | 06:56 AM
paulroad's Avatar
Tech Guru
Default drawbacks...
you need the O2 Sensors relocated or a spacer-bung installed or codes will result when the o2 sensors get fried.
You will get an increase in power but, it may not be worth the cost. You should first do an exhaust upgrade.
kk's woW12
Dec 11, 2008 12:32 PM
spitfire_11
12v V6 Discussion
Oct 19, 2007 03:14 PM
2001s4loored
Sep 1, 2006 01:29 PM
RMcQ
Mid Atlantic Discussion
Feb 7, 2006 04:22 AM
Mr. Ricco
Jan 25, 2004 05:31 PM
