PSA - Check your brake hoses..
Old May 21, 2008 | 10:27 AM
audikillsbmw's Avatar
Member
Default PSA - Check your brake hoses..
I know it's been mentioned before, but I figured I would bring it up again. Make sure you check your rubber brake hoses. When I had my front wheel off yesterday to test fit the spacers, I noticed that one of mine is cracked So make you sure you check yours on a regular basis. And despite warnings from some of the guys on here, I think I'm going to try out the Stoptech stainless lines. If I decided that they're a bad idea, then I'll install a set of OEM lines.
Old May 21, 2008 | 10:36 AM
Paracaidista2.7T's Avatar
I have Goodrich with no issues.
Old May 21, 2008 | 10:42 AM
Pete RD's Avatar
Default It is VERY WISE to check ALL BRAKE LINES (stainless or not) annually.
Even stainless lines are subject to wear.
HTH
Old May 21, 2008 | 10:43 AM
Member
Default What did you pay for them? A full set of Stoptech lines is $160, but I'm just
going to buy the front lines for now ($60.)
Old May 21, 2008 | 11:10 AM
Press's Avatar
Fear the Miata!
always check my ss lines
Old May 21, 2008 | 11:24 AM
Member
Have you ever had any problems with your ss lines?
Old May 21, 2008 | 11:40 AM
JimtheDentist's Avatar
Default FYI: Just ordered a set of 4 from 2Bennett @ $120
<ul><li><a href="http://www.2bennett.com">http://www.2bennett.com</a</li></ul>
Old May 21, 2008 | 11:44 AM
Member
Nice
 Pouria Savadkouei
 Michael S. Palmer
Old May 21, 2008 | 12:29 PM
BernieBenz's Avatar
"Always" is a bit too often!
Old May 21, 2008 | 12:30 PM
BernieBenz's Avatar
Default And just how do you check your brake hoses? Visually, for surface cracking of the abrasion cover?..
IMO, another meaningless exercise, designed to sell hoses. Industrial service hydraulic hoses are often made with perforated abrasion covers, such that they will not balloon with a pin hole leak in the interior pressure hose.
