Bleeding Brakes
Old May 21, 2008 | 11:32 PM
ThereRobert's Avatar
New Member
Default Bleeding Brakes
Is it absolutely necessary to bleed brake system at every pad change?
The pedal feel is not perfect but definitely manageable.
Thanks to anyone who doesnt mind answering my dumb question.
Old May 22, 2008 | 03:02 AM
4Driver4's Avatar
Tech Guru
Tech Guru
Default No. But it's a good idea.
I like to open the bleeder before retracting the piston so that the fluid in the caliper is pushed out the bleeded rather than back through the master cylinder.
Old May 22, 2008 | 04:55 AM
donp's Avatar
The fluid is supposed to be replaced every two years anyway.
Old May 22, 2008 | 05:04 AM
02 Silver Arrow's Avatar
Default You are in the same area replacing the pads it just is an easy time to do what is routine maintenanc
Get a preasure bleeder from purems works like a charm
Old May 23, 2008 | 08:46 AM
2.7T_M6's Avatar
The maintence scedule on my car says to do it every 2 years. Appently these cars need it.
Old May 23, 2008 | 03:04 PM
donp's Avatar
The interval is because brake fluid is hygroscopic. Moisture builds up in it over time.
albertaA4
Apr 19, 2007 05:33 PM
PrelateBishop
Brakes Discussion
Aug 4, 2005 06:49 AM
S4gasm (LoTR)
14
Mar 16, 2005 06:44 AM
CaseyH
Jul 22, 2004 11:15 AM
abcdefghijklmnop
May 13, 2003 05:47 PM
