Replacing rear rotors and pads
Old May 23, 2008 | 05:47 AM
02AudiKing's Avatar
Default Replacing rear rotors and pads
I went to the dealer to get my abs and esp light checked out and they fixed it and told me my front pads and rotors needed to be done and rear pads alone. I did the front pads and rotors using dealer parts( i should have upgraded to cross drilled rotors)...I really needed them so i just put on the factory ones...now i want to do the back brakes i have the dealer pads but should i do the rotors too? if so, im thinking about upgrading them to cross drilled, will this cause problems?
Old May 23, 2008 | 05:57 AM
SNAFU 4's Avatar
Default If you didn't do cross drilled on the front, I would not bother with the back...
I don't think it would cause any issues if you did... but would just look odd and not give you any advantages anyway.
Old May 23, 2008 | 06:05 AM
02AudiKing's Avatar
Default Thats what I was thinking...
Ill put on oem rotors on the rear and just upgrade the next time i have to change em...thank
Old May 23, 2008 | 06:15 AM
4Driver4's Avatar
Tech Guru
Tech Guru
Default "i should have upgraded to cross drilled rotors" Cross drilled rotors are not an "upgrade".
Use flat rotors front and rear.
TToneSpasm
Aug 15, 2008 05:19 PM
sergeyk
Audi Original "S" Cars
Mar 6, 2006 02:55 PM
powderquattro
Jan 10, 2006 01:36 PM
s ate
Jul 5, 2004 07:10 PM
Eric M.
Jun 16, 1999 06:43 AM
