Thoughts on this brake upgrade....anyone running it?
RPI EQUIPPED Passat B5, Audi A4&A6 - Audi 5000TQ
13x1.25" diameter two-piece (lightweight) rotor.
Vented, slotted and cross drilled rotors for maximum fade resistance.
Each rotor is also silver CAD plated for long lasting good looks, with a billet CNC chrome plated centre hat.
Compact billet aluminum Wilwood 4-piston caliper provides superior clamping force while allowing unsurpassed wheel clearance.(17" min. diameter)
Billet CNC aluminum chrome plated brackets and Goodridge stainless lines complete this pre-assembled package which provides not only killer stopping power but a 25 lb reduction in unsprung weight.
Each kit utilizes the latest Wilwood 'fast-road' compound pad. These pads provide excellent bite on the street and will get you through track days as well.
Assembled with grade 12.9 hardware
You'll definitely need replacement pads and potentially both road and track pads. Its also likely that you'll need replacement rotors, particularly if you plan on tracking the car. Its also possible that you'll need new hats and hardware at some point. If this stuff isn't readily available, your car will sit while you wait for parts - not fun. If the kit is low production and/or changes over the next couple of years, parts availability could be tough.
Sometimes the latest/greatest isn't so great. tried and true has a lot of benefit
Good luck
Mike
Be careful with Wildwood; they are primarily a racing caliper company and many of their calipers do not have the weather boot on the piston. This means that they need frequent rebuilding. Again, not true of all Wildwoods, but you have to be careful with racing application stuff.
