Diagnosing a intermittent misfire?
My car (03 A6 with 3.0) is having Idling problems for about couple of weeks. It had a code P0300 and P0305- Intermittent misfire in Cyl-5; I replaced the plug and Coil and it still has the same code.
The Error Light came on after 100 miles or so and the only thing it exhibits is, it hunts to find the right Idle by about 100 RPMs, when I give a little gas (in neutral) and has slight vibration when I start it (cold engine) for a few seconds...
The car has 40k miles but out of warranty, wondering if it's a bad Injector or anything else. I do not have VAG, but found a Generic cable and used Shareware to pull the Code.
anyone else have had similar problem; if so, what was the diagnosis?
Thanks in advance!!!
the other plugs practically looked clean with out any deposits. I am not sure why its just the cyl-5 even after replacing plug and coil.
I did add seafoam to a tankful of gas. I had the code after that tank of Gas, it's possibly a coincidence. The Idle wavers by around 100 RPMs and it does for longer duration when I switch the A/C on or off.
Thank you both...
I tried to read the blocks using shareware and the MAF reads fine and it even peaked at 179gm/sec which I think would a average number for a 3.0 engine.
The injector run time is weird though, it actually is decreasing in time interval when ever the idle wavers.
I shall try to replace the plugs and also the remaining coil packs.
Thanks.
